Poulan 3700 cracked starter pulley
   / Poulan 3700 cracked starter pulley #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
I borrowed a chainsaw from a guy at Church and it broke while I was using it.
It is an old Poulan 3700, refitter with an Oregon 18" bar.
The starter pulley cracked in half (perpendicular to the shaft).
They stopped making parts in 2009.
I have been everywhere (except TBN) and can't find parts.
Got any good ideas?
I have pics on my laptop, can't figure out how to link them to the message.
The key differentiating feature is the pully where it interfaces the flywheel has 2 posts, and NOT a hexagonal shape.
The saw was running great and cutting well right up until I could no longer start it.
Thanks in advance,
David
   / Poulan 3700 cracked starter pulley #3
I thought you needed recoil. Here is just plastic pulley. Could you show a pic of the 3700 pulley. Below is a 3.7 3400 3800, I want to see the difference.
Sears Craftsman 3.7 & Poulan 3800 / 3400 starter pulley | eBay
which one?
No sir, both are not right. they are hexagonal, I need two pins sticking up and engaging two "v" brackets on the flywheel...
I will take a better picture tomorrow, the saw is at my other house...
   / Poulan 3700 cracked starter pulley #6
I have a polar 3400 counter vibe that might be the same, post up a good picture and I'll see if it is the same. This saw is collecting dust at the present time and might be a good parts donor.
It looks like this other one in 2nd pic works on that flywheel dogs. It's round http://www.tractorbynet.com/forums/...ulan-3700-cracked-starter-pulley-100_0180.jpg
xyz123 - I'd be willing to try, but it is VERY different from what I have here. The dealer tried the others you showed from ebay etc. and they would not engage.
Fixemall - It is a 3700 counter-vibe, but the 3400 parts I've tried would not work. I will try toget a pictiure tomorrow, the saw is at another house of mine. I will be there doing some work tomorrow & will try to snap a pic.
Thanks to you both!
David
Sorry it took so long. Here is the picture I promised of what I need it to look like.
David
   / Poulan 3700 cracked starter pulley #9
Your needing just the plastic pulley in your pic? Can you take it off and find the part number on the other side?
I know of a bunch of online poulan parts dealers. If it is around.
Yes sir!
They quit making parts in 2009, but the part # is either missing, illegible, or buried under a layer of grime. I will look further when I can get dirty (I'm working my J O B right now...).
Thanks,
David
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2006 GAYLEAN  130BBL (A52472)
2006 GAYLEAN...
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2020 KENWORTH W900L DAY CAB (A52472)
2020 KENWORTH...
