Potential power increase for CK2610?
   / Potential power increase for CK2610? #111
In case your sleeve becomes damaged or destroyed for some reason, it looks extremely simple to put it back to the factory look. However, I would probably purchase ahead of time to make sure everything is exact. Put #1 to desired location. install 3, 2, 3, 4,5. Then slightly tap #6 over the entire assembly. I am assuming #6 is the sleeve. And I would be willing to bet that this is the same for the CX2510 since it has the same displacement and model # of engine.
   / Potential power increase for CK2610? #113
I have never touched the fuel screw , but the shims were removed by the dealer and told me it wouldn't effect the warranty but turning up the fuel would. My machine has all the power necessary for it's size. I plowed a ft of snow this morning in high on the level and slight slopes. Mid range for steep hills I'm able to plow in both directions up the hill as well as down.
   / Potential power increase for CK2610? #114
I've been reding thru all this and hoping to apply it to my CK2510H. It has a different engine
Daedong 3A139LFB
diesel
3-cylinder 6-valve
but I am hoping it will work. It appears that there are two lock/jam nuts and the center screw with the slot is the actual adjuster. Cutting off that tamper-proof cylinder appears to be the hard (scary) part.
With only two gears, High and Low id be nice to have more HP so I can doo more in high, like using the FM or rear blade, or even climbing the driveway with a full bucket at more than half pedal.
BTW my tractor will rev to 3000 rpm with the throttle stick all the way forward and I sometimes do this when driving up the driveway in High gear. I assume this will not damage my engine.
   / Potential power increase for CK2610? #115
I don't know if anyone knows the answer, but pertaining to the fuel screw, the parts diagram looks like it can just be threaded out, if it needed to be replaced can you just thread it all the way out and replace it? If so what is the stock amount of turns from bottomed out?
   / Potential power increase for CK2610? #116
Has anyone considered buying the shim pack for the older CK35 and comparing between the two? I found a parts diagram but the numbers didn't seem to be correlating correctly. If the timing/duration is the difference between the 26 and 35, I'd much rather turn it up that way than with the fuel screw.
   / Potential power increase for CK2610? #117
It’s timing AND fuel. Timing is measured in degrees. The amount of shims needed can be different from one individual tractor to another. It’s not a ‘pack’ that you buy, install the whole thing, and everything is magically in spec. It could be as simple as removing the pump and taking out one of the existing shims to get the proper ck35 advance. Won’t know until you try to time your tractor to the new spec. The difference each shim makes is in the 2610 service manual.
Then you adjust the fuel screw. ;)
   / Potential power increase for CK2610? #118
Thanks for the clarification. I believe someone else asked (but it wasn't answered) whether or not the fuel timing duration also increased with the lift when removing the shim or whether it was just max lift. Either way, sounds like it's not enough and requires the fuel screw adjustment as well.
This being said, do they really manually time all of the engines individually? Seems like their machining tolerances should be close enough that standard shim packs can be used. It's definitely possible but surprising to me.
Thanks again!
   / Potential power increase for CK2610? #119
If one wouldn't adjust the timing anyway (for all other operation) why would they do it?
The the rack adjustment raises the max fuel the governor can supply, according to throttle demand and load. And it can be harnessed at any rpm, not just at PTO or max. But nothing will change during any operation that doesn't require more hp than the original setting held to its rating.
The power will be there if/when you need it and more fuel can be delivered. That's the goal and it's really too simple. IMO if you run a slasher it's an absolute must.
   / Potential power increase for CK2610? #120
Yeah I guess I was basing most of my thought process on the one poster who said his dealer removed the shim(s) and that's all it took to get it to 35hp. I'm also curious, if that's all they did, how they actually timed the injection. Again, PTO dyno would answer all questions but I'm not aware of one near me.
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2014 Jeep Grand Cherokee (A56859)
2014 Jeep Grand...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
Yamaha (A55758)
Yamaha (A55758)
