Potable air compressor you should have.....
   / Potable air compressor you should have..... #1
jkk04
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
Modern technology is amazing and makes life so easy.
   / Potable air compressor you should have..... #2
Looks basically worthless to me. Miniscule air delivery and it's plastic to boot. Real air compressors are made from metal.
   / Potable air compressor you should have..... #3
Wont work on my work trucks, unless i have loads of time. I carry a Dewalt 20v cordless compressor on my work rig already…..that airs up a tire pretty fast. But it is amazing the things there coming up with.
That was exactly what I thought first but it works for me so well...
especially on riding mower tires and compact tractor tires.
Jkk
   / Potable air compressor you should have..... #5
All I have is large tires and I don't want to spend all day filling them either. Even my little pancake compressor is huge compared to that.
   / Potable air compressor you should have..... #6
Those are not really made for large tires. I tried using a Kobalt one for larger tires (Car). It worked for about a year of about 15 or so tire top offs and then died. I got another one but only use it on bikes, mowers, dolly, and other small tires. It is great for that.
   / Potable air compressor you should have..... #7
I have the 60 volt DeWalt battery powered air compressor. I bought it when that's all they were selling at my local store. I wish I had the 20 volt because I have several batteries, but I only have 1 60 volt battery, but it still works, I just have to be sure the battery is charged up. I had bought a larger 60 volt battery and it died in fairly short time, and I will probably buy a 20 volt compressor before I buy another 60 volt battery.
   / Potable air compressor you should have..... #8
I have one of these RIGID tire inflators, had it for a couple years and use it all the time because my tractor tire has a slow leak. Works great!
   / Potable air compressor you should have..... #9
I thought the 60v one worked on either the 60 or the 20v battery? I got the one that only works on 20v as i have 10 of these batteries already.
   / Potable air compressor you should have..... #10
DeWalt batteries seem to be coming down in price. I just bought a pair of genuine 6 aH batteries for $100 delivered.
2020 John Deere 5065E  4WD Tractor (A49251)
2020 John Deere...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2015 Ford F-250 4x4 Super Duty Ext. Cab Pickup Truck (A46684)
2015 Ford F-250...
2022 Champion 100330-1 37 Ton Log Splitter (A49339)
2022 Champion...
PoleCat PC266 Towable Aerial Platform Lift (A49346)
PoleCat PC266...
1999 Ford F-150 Pickup Truck (A48081)
1999 Ford F-150...
