Posthole Digger Posthole Digger Preference
   / Posthole Digger Preference #51
Seems to be a lot said about shear pins, very little mention of safety clutches most diggers are only are as powerful as the adjustment on the safety clutch. which should release before the shear bolt breaks.
A Penco head is the way to go, any PHD is only as good as the cutter, a 12"
auger is a good all round size, strainer holes usually have to be barred out,
depends on the post size.
   / Posthole Digger Preference #52
Isn't that really true based on the size of the tractor. Based on the info I have seen on the bynet, most smaller CUTs can handle a 9 inch even in tough terrain with the correct bit, but larger than that and seems like you would need a large supply of pins?
   / Posthole Digger Preference #53
Has anyone had success with a SpeeCo brand? It is a cheapy from our local Farm & Ranch store. The company's been around for 50 years. It has the replaceable teeth on the auger & seems like it may work for our small acreage.
   / Posthole Digger Preference #54
Hello this is my first post. So be easy on me. I did a search and thought I'd add to this thread. PHD have been covered a few times but I'd like to buy a new bit for my unit.
I have a Leinbach post hole driller / auger. I have a 12" diameter auger. I don't really like the tip. Its mostly flat and the center has an approximate 2" tall 2" wide at base triangle shaped flat bar that acts like a spade drill for a pilot.
My problem with the unit is that its very hard to keep on target starting a hole. The tip has no real piloting action. If on starting a hole a side of the auger tip hits a rock or clump of grass it turns off target. The center point provides no real pilot action what so ever.
I have seen some of the 6" and 9" augers with a 4-6" tall cone shaped drill point and that looks like it will stay on target better. My gear box has a round ~2" shaft connection with 2 bolts oriented 90 degree apart at ~3/4" and 2-3/4" from end. I'd like to buy a new auger bit for the gear head.
Anyone have a better auger bit that is compatiable? I am thinking about a Speeco bit (I think that is the one at The Tractor Supply Store). Opinions of quality and performance please. I'll be using it in light to medium red clayish dirt.
I think the 2" round shaft and 2 shear bolts are a fairly common connection???
I would rather not buy a whole new PHD as I only fence a little at the time. I have put in several hundred holes with the Leinbach and replaced the tip a few times. IMHO Leinbach is a an inexpensive light duty unit that digs OK especially if the soil is clean and flat to start. but the tips are soft and a margin wears on the blade pretty quick then it doesn't penetrate - just rubs a hole real slow and the above complaint about starting a hole. If I knew then what I know now I would have bought a better unit the first time.
   / Posthole Digger Preference #55
I have the Speeco brand unit. Yes ,it is cheaper priced, and probably cheaper built than most others. But it works well. The output shaft from the gearbox is 2 inch round. Speeco sells augers for it of course. 9 inch and 12 inch. But Northern Tool also sells augers for their own powerhead, that also happen to fit the Speeco gearhead. I found that the 14 inch auger that Northern sells weighs about twice what the 12 inch Speeco auger weighs, and is more aggresive, for little more money. 14 inch gives a nice margin with setting 6x6 posts. 12 inch is about bare minimum, and leaves almost no room for error correction. I run mine on a 21 Hp tractor, drill in clay with rock. I run the tractor at just above idle, it does not take much power at all. You want to remember to pull the auger out of the hole as soon as the flighting is full, don't expect it to keep pushing the dirt out. If you dont pull it each time it fills (when diggin in clay) sooner or later you will drive it in. Once driven in, it must be turned backwards to get it out of the hole. This is no fun. One guy on this TBN described how he added a pipe section welded onto the auger shaft near the top end, so he could insert a shovel handle to get leverage to turn the auger back out of the ground when needed. This sounds like a really good idea and I plan to do this before I need the unit again. This would be the great advantage of the hydraulic unit, you could reverse it. But too much money.
   / Posthole Digger Preference #56
I have a hydraulic auger head with a 12" bit that is powered by my Kanga mini skid steer. It has some really nice replaceable teeth and with the down force I can dig a 4-1/2' deep hole in no time. If I hit something that overpowers the hydraulics then it stops and I can reverse it to clear the stoppage. I've also had it dig faster than the down force since I have to provide a ceratin amount of down to match the digging rate. If this happens in hard red clay then the back of the machine is lifted, with me on it. More than once I've had to reverse the auger to put the machine back on the ground.
Yes, the hydraulic augers are more expensive but that ability to reverse it out of a hole sure beats barring a stuck auger out. Plus you can mount it on the side of an FEL bucket which makes it more versitile and allows downforce without any modifications.
   / Posthole Digger Preference #57
The post hole digger that Northern Tool sells is the FM5500 made by Green Mfg that ducati996 posted a link to earlier and can handle up to the 14" auger.
   / Posthole Digger Preference #58
The CCM hydraulic toplinks and side links with double piloted check valves will arrive at CCM on Monday April 2. Please give us a day to check them in before you call and place your order. We will start taking orders Tuesday April 3. ALL sizes should be available.
Thank you for your patience and support.
Mark Carter
   / Posthole Digger Preference #59
Gents
My L3010 came with a McMillian 12" auger that attaches to the FEL frame. Works great, but don't have any pricing info handy.
   / Posthole Digger Preference #60
I can't tell you how many holes I have done but I have yet to snap a shear pin. I have had it stall the tractor if it gets into a bind. Digging soil is a low RPM task. If your cranking up your tractor to punch post holes you have other issues with you auger. dull or broken tips possibly. Some times the auger is the wrong tool for the job. You might just have to punch the 1st foot by hand. Welcome to Earth. The best of life makes you sweat
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2018 Wacker Neuson WL 38 (A52128)
2018 Wacker Neuson...
UNUSED FUTURE MINI SKID STEER SIDE SHIFT FORKS (A51244)
UNUSED FUTURE MINI...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
