Posthole digger on1700D
/ Posthole digger on1700D #1
RonJ
Fort Worth, TX
What's the largest posthole digger that I can reasonably use on a 1700D? I'm in Central Texas and know that there will a few rocks and hard layers of caliche. I need to go about 3 feet deep and need each hole to be 12" in diameter.
/ Posthole digger on1700D #2
I use one on my 1500 and a 12" auger, it can drill down about 700mm depth with the auger I have and it does it easily. Rocks, roots and the like don't slow it down much. If it won't drill I jump on the frame to give it a start.
/ Posthole digger on1700D #3
Power would not be an issue. All post hole diggers are not created equal. The main thing you need to look at is whether the digger will fit your 3 point and allow proper up and down movement with the 3 ft auger you desire. Many diggers have different top link holes that allow considerable up/down adjustment. There are numerous videos showing proper use of these. You might find some of them informative.
With my limited experience with diggers I learned the sharpness of the auger bit is important in hard ground.
Thanks for the info. Maybe I can get the wife to jump up and down on the digger when I hit the caliche. NOTE: If she sees this post she'll be jumping up and down on me.
Winston1-Thanks for that info. I wouldn't have thought of it. I'll definitely be looking for those videos.
/ Posthole digger on1700D #6
That too, my auger has a bolt on leading edge which can be sharpened or replaced.
/ Posthole digger on1700D #8
just used mine with a 12" auger until I hit the hard packed clay 28 inches down, but that was enough for me.
/ Posthole digger on1700D #9
Read up on safety, first. That is supposed to be one of the most dangerous things you can do around farm equipment.
Cal's right, I shouldn't have said that. You could very easily get caught in the PTO shaft and that would be disastrous for anyone on there.
