Posted signs
/ Posted signs #1
Haz
Northeast PA
Kubota L3430cab w/ FEL
We recently bought our property in the last year and after we had a survey done, I went around to locate the property lines and corners since the surveyor had marked them out nicely. We are planning on building a house on the property in the spring but go there quite often now to spend time and walk through the woods. On the south side of our property, a neighbor owns 4 acres. He seems quite friendly. His put posted signs on his property probably sometime in the last year or two and I noticed that the newer ones are on trees located about 20-50 feet on my side of the property line. Is this a normal way to post signs? I bought some and am mounting them on boards and am planning on putting them up in the next two weeks before deer season. Any comments on where I should locate my signs (i.e on the line or back somewhat). Do posted signs such as this neighbors in any way indicate someone's claim to property? Any advice would be appreciated.
Haz
/ Posted signs #2
Is the property fenced, if not, maybe he is unsure where the property line is located, if not he he is trespassing to post his land. Normal practice around here is to post on your own property.
/ Posted signs #3
Sounds like my battle 20 years ago.... My neighbor posted NO TRESPASSING signs on my property and proceeded to claim the property. They also claimed ownership of the road to my property and said I was land locked, but that is another part to the story that I won't go into now. It took many thousands of dollars to defend my claim and I was not reimbursed for any of it through the title company. Now, 17 years later, even after the battle was settled, and the court approved the boundary line agreement, the survey recorded, and quit claim deeds signed by both parties, they continue to violate my land and trespass.
First, I would suggest that you have your survey registered with whatever governmental agency records deeds and survey maps. Then have the surveyor come back and walk the boundaries with you and if possible have a third neutral party with you when this happens, so if you wind up in a court battle, you can bring in the neutral party to testify what the surveyor has said. Then, and only then, remove his signs in front of the surveyor and dispose of them. Also put your signs on all the trees that are closest to the property line and space them approximately 50 feet apart. Many states have a standard for this spacing, but more are better. Then photograph the surveyor and the neutral party at each pin and make certain that the pins are driven into the ground to a point that they can't be removed easily. Many people will either remove a pin or relocate it. Both actions are illegal, but you have to prove who did it to prosecute and that is a difficult task unless you actually see them doing it. Every one of the pins that the surveyor placed on my common boundary with my neighbor has been removed. I know that I didn't do it, but I can't prove who did do it, so I am left with the cost of having them re established. Document everything and don't take anything for granted. People will fight tooth and nail for inches when it comes to land. Hopefully you don't have a deed that is vague such as from the snow pile to the oak tree along the fence line and all these things were there in 1900 and not in 2003.
One thing to consider is to remove every tree that is on your property that is close to the property line so you will have a clear line of sight of the pins. It would be best to have the surveyor there telling you what trees to cut. I have learned a lot in the past 20 years and the one thing that I know is that when someone claims your property as theirs, the only winners in the end are the lawyers.
If you are so inclined (translates to brave), ask the neighbor if he has had his land surveyed and if he has, ask to compare maps. Then if there is a discrepancy, ask the neighbor to have his surveyor contact your surveyor and try to resolve the differences. If the neighbor never has had his land surveyed, and is relying on hearsay, then you are in for a battle unless he can be convinced otherwise.
If you have the time, you can do a lot of the research yourself by looking up the land records and getting a copy of his deed and comparing it to yours to see how the boundary line language compares. Also ask if there is a map of his land on file. Try to go back in the records as far as you can to see if anything has changed on the deeds from transfer to transfer. The more homework that you do the less it will cost you in legal fees. The deeds and maps are public record and aren't very expensive to get copies of them. Start building your file of pictures, and documents now. Keep a note book of all conversations and what was said. If you have a video camera, even better.... make a movie of everything. I am certain that others that have been through this will also have other suggestions too....
/ Posted signs #4
I would think it normal to post signs on the property line or on your own property.
Deliniate your property lines as soon as feasable. Junkman has given good advice.
Egon
/ Posted signs #5
Very good advice from Junkman. I would just go talk to them asap. When you had your survey did you have blaze lines set ? or just a boundry survey with pins ? If you just have a boundry survey its very easy to get a bit confused. It is fairly common to put sign ON the line. I did this as did my neighbors when we were both new. since then the only ones that remain are on the road. If they seem like reasonable people the good news is that its usually pretty easy to sort out with a friendly conversation. Dave
/ Posted signs #6
Just a couple of weeks ago I was told the easiest way to tell if your new neighbor was from the city was if the first thing they did was buy and post no trespassing signs. /forums/images/graemlins/blush.gif
It's been my observation that the way we act in the city eventually becomes the opposite of the way we act in the country.
I'll go in and put in a fence around a five acre Mcranch or Mcfarm. Invariably it will be pointed out to me that the neighbors are too nosey and seem to know everything about everyone.
I'll come back in five years later and they will update me on just who has what and if they've done this or that, about the whole neighborhood. /forums/images/graemlins/smile.gif
It has always been interesting to me how folks in the country know everything about their neighbors. But in the city people don't know squat about the family two doors down.
I've finally decided it's all about congestion. When we're stacked we shut ourselves down and limit our exposure, us to them, them to us. When we have space then we become fascinated with the world around us, even the neighbors.
I do a lot of work in the country for folks from the city and the country. I've come to the conclusion that conversation and communication with the neighbors is the best way to keep your yours and the way you want it.
/ Posted signs #7
Thats really well said and based on my experience is the dead on truth. I live in the typical sub urban sub division. 85 home sites. I know my immediate neighbors on three sides but most of the rest I have no idead who they are etc. We only have 1/2 acre lots and the guy next door has never said six words in three years. Two or three doors down I have no idea. At camp My property is five miles in from the main gate. I know 70% of the people really well, exchange numbers emails, talk dureing the week, get together for a cold one watch each others prooperty etc. Every time some one new from the city buys in, Up go the signs. I did it too. A year later 80% of those signs are down. just dont need em. Talking and getting to know my neighbors has been the best solution. Dave
/ Posted signs #8
I'm just curious. What are blaze lines?
Thanks,
Kevi
/ Posted signs #9
</font><font color="blue" class="small">( He seems quite friendly. )</font>
Haz, I'm going to suggest the direct approach like several of the other posters. I'd just go talk to him. Tell him you got a survey so you would know where the property lines are, and ask him to walk the survey lines with you. Either while you are walking or before you walk, talk to him about putting his no trespassing signs right on the survey line, mounted to t-posts or something similar. You'll be able to judge how serious he is about the signs and he may even volunteer to take them down or move them. Essentially, I always give folks the benefit of the doubt until I have reason to believe they will resist. I always represent my surveys as my wanting to make sure I don't encroach on their land. Most of the time things go pretty well. I also make it a practice to only put up no trespassing signs along the county road. I don't think it makes the right statement to put up signs along the property lines between me and my neighbors.
After making this attempt to come to agreement, your neighbor will either agree or state his resistance. At that point you would have to escalate your pressure, but I'd try to keep it friendly unless you see you have to force the issue.
/ Posted signs #10
Jim, that sounds like great advice. My wife and I are about to buy 10 acres or so and this thread has been really informative. Junkman's advice was pretty darn good too -- spoken like a true lawyer (I realize that, to some, that might sound like an insult, but I really did mean it as a compliment). The only thing I would add is, when you go to talk to your neighbor, don't forget the cold ones to help the discussion along! /forums/images/graemlins/laugh.gif
/ Posted signs #11
Blaze lines are " line of sight ' views down a property line. For example in the woods a Surveyor can not get a true reading in many areas and must rely on GPS and must have a existing starting point. In my county those origional iron survey posts are from about 1880. With blaze lines they can shoot a straight line through that scope deal you see them lookin through. This is over simplified because as you can tell I am not a surveyor. The Trees that are in the line of sight must be cut so you wind up with a trail down the property line through the woods and brush etc. Now if you have thick woods like mine it is VERY easy to just poke around one tree and think wholly cow wheres my line ? With just a boundry survey in areas it can be virtually impossible to say the property line is the third tree on the left. Blaze lines are not the be all end all but they certainly make a real statement that your property has been surveyed and There is the line. My surveyers were very good and did work around a couple of large maples insread of cutting them. I since have boought the adjacent lot so I now have two parcels and I keep two tax ID numbers as I had already paid for the survey, blaze lines and to have the creek traveresed. To give you a idea about what I mean by finding the first way point the surveyors had to pretty much survey the unsold 80 acres next to mine to get a solid line off the County marker. My first survey with blaze lines and traversing the creek ( water surveys add big $ ) was $2800 When I bought the adjacent lot they had already done most of the work and the same survey was $600. All money well spent. In the initial survey it would have been more like 4k if my neighbor on the other side did not already have a blaze line set. In my area this is a whole lot of saw work, brush busting and creek wadeing. Dave
/ Posted signs #12
When we bought our land, we posted it too. Some of our signs turned up missing on one boundary. After the leaves were off the trees, I could see that I had strayed onto my neighbors property.
I called him and asked if he could help me with the property line as I wanted to post the property correctly. We met and had a good time walking the line and putting up the posted signs together. Nice guy, he just did not like the idea that my signs were on his land. He still hunts our land and we always have venison in the freezer.
/ Posted signs #13
</font><font color="blue" class="small">( We met and had a good time walking the line and putting up the posted signs together. Nice guy )</font>
I think this is the way I would attempt to go. You might find your neighbor very receptive to a walk through the woods.
You might even make a new friend out of it. /forums/images/graemlins/laugh.gif
/ Posted signs #14
<font color="blue"> I always represent my surveys as my wanting to make sure I don't encroach on their land. </font>
Me too. That way, it doesn't seem hostile to them.
/ Posted signs #15
Haz,
Its not normal or likely legal to post on someone elses land. Its
likely that your neighbor did not no the exact boundry when he
put up the posted signs. Even following a compass heading
it very east to get off the line... Just have a talk with them and
see if they will walk the land with you. I did this with my
newest neighbor when he moved in.
One of my neighbors, a big timber company, had posted signs
on part of my land. It was not on purpose they just did not
know where the line was located and they where off a few
yards.
Check you state law on how to post. In NC the signs have to be
a certain size, 12x10 inches I think, have certain verbage, AND
be located certain distances apart. If you don't meet those
standards then your land is not legally posted.
In NC, one of the VERY big reasons to post is to limit the land
owners liability. The trespasser has a harder time sueing
when they are comitting a criminal act. If the signs are not
up then they can legally wonder you land and if they fall in a
stump hole they can sue and have an easier case. At least
that is the way I remember a document that I read from the
state. This might not be applicable in your neck of the woods.
Later,
Dan McCarty
/ Posted signs
Thanks everyone for the advice. I will plan to go talk with him and walk the boundary lines with him so we can set our signs. He seems like a very nice guy and I'm sure it won't be a problem. I will take a copy of my survey along in case he has any questions. I may not even post anything on his boundary. The neighbor has a 4 acre parcel and my land happens to wrap around his on three sides.
Haz
/ Posted signs
Junkman,
Prior to purchasing the property, we had to have a certified survey done so that we could get title insurance. We actually got about 30 more acres in the deal than we had anticipated because the land was a residual tract and the seller didn't know how much his father had sold off over the years so he didn't know exactly how much land he was selling us. The purchase price was a set price for the entire parcel so he couldn't ask for more money for the extra land. Of course prior to the survey which we had to pay for, we didn't know exactly what we would get either. Anyway when we did the closing, a mylar copy of the survey was recorded in the County deeds office. We have the only known survey of the entire parcel on record so legally we are in a good position. Someone would have to pay for a rather expensive survey to challenge ours.
Haz
/ Posted signs #18
Haz, When you talk to your neighbor about walking the lines with you, don't forget to mention that he and his family are more than wlecome to enjoy the woodlands and wildlife on your property even though it is posted (assuming that you don't mind). I have done this with several neighbors and it goes a long way to show that you really do want to be a good neighbor.
Mini Bucket Excavator Attachment (A61572)
Mini Bucket...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2018 INTERNATIONAL...
2016 John Deer 5075E (A60462)
2016 John Deer...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2024 John Deere 6R 155 MFWD Tractor (A63109)
2024 John Deere 6R...
