POST YOUR PICTURES OF FORKS?
   / POST YOUR PICTURES OF FORKS? #61
Forks are also useful for removing unwanted growths. /forums/images/graemlins/smile.gif
   / POST YOUR PICTURES OF FORKS? #62
Those are pretty cool - I would like to have some in Blue please to match my New Holland. Where did you get the forks?
Just as a note, please try to resize photos to 640 x 480 or smaller before posting as images within a post. Larger pictures distort the formatting in the rest of the posts within the thread, requiring scrolling to read. /forums/images/graemlins/smile.gif Another alternative is to use a link Showing Cool Homemade Versatile Forks
   / POST YOUR PICTURES OF FORKS? #63
Po' Boy's free pallet forks:
I'm collecting several piles of bricks Dad had stacked in diverse places.
My neighbor noticed and offered some old pallets to stack them on.
The attached photo shows my zero-cost 'pallet forks' that served
to get the pallets home across a quarter mile of rough ground.
Just a couple of 2 x 4's run through the pallets.
I'm going to try loading each pallet with a 10 inch stack of bricks,
and bring them to a single stack of loaded pallets.
I'm having a great time with my 'new' (1980) Yanmar 240. Great toy!
   / POST YOUR PICTURES OF FORKS? #64
Hi,
Nice design! I need a brush rake and was thinking of modifying what you have done by using 1/2 x 3" up on edge instead of the 2x2's that you have. Also space the "tines" about 8 or 10 inches apart and have at least 6 with a cutting edge welded on top, back from the leading edge 10 inches or so to cut roots as I go. Do your 2x2's project out about 18 inches from the bucket? Or? Would you make them longer/shorter if you had to do it over? Are you happy with the bolt on or would you switch to a clamp on rig? I wonder if I should add replaceable teeth at the cutting angle on the 1/2 x 3?
Thanks in advance, Prentice
   / POST YOUR PICTURES OF FORKS? #65
Hi,
Great job! What did you use for the 1/2 round at the top connection - pipe? That looks like it could be a real weak spot if I didn't make it beefy enough.
   / POST YOUR PICTURES OF FORKS? #66
The "half-round" top connection is 3/16" plate that I heated and bent. I also used 3/16" bracket to reinforce it on top. That is pretty much the same design that is used on the JD buckets.
top connection picture
Steve
   / POST YOUR PICTURES OF FORKS? #67
Prentice-Yes, the 2"x2" extend about 18". If I did it again, I might make them 24", but they work pretty well for what I use them for, mostly carrying brush, logs, and downed trees. I like the bolt on method. It is just as quick as a clamp on. I usually just hand tighten the nuts since the force is upward. The advantage is that there are no obstructions in the bucket. I can fill the bucket with short logs, stumps, brush, etc. and dump it with no problem.
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
golf cart electric (A55787)
golf cart electric...
1997 Ford E-250 Cargo Van (A56858)
1997 Ford E-250...
MOBILE BBQ GRILL (A52708)
MOBILE BBQ GRILL...
THREE POINT WYLIE SPRAYER (A58214)
THREE POINT WYLIE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
