POST YOUR PICTURES OF FORKS?
   / POST YOUR PICTURES OF FORKS? #51
Here is what I built for mu BX2200 Kubota.
I have been using a TSC 3 pt carry all platform, and didn't think I needed any forks, even after reading all the good info on the TBN page.
Well I had to move a bunch of pallets and some limbs I had cut off.
The platform will move stuff like that, but it will only lift as tall as the 3 pt will go, which isn't very tall and I had to pick them up to load them, pick them up to off load them, then lift them onto the burn pile.
So I started looking at what the TBN group had done about home built forks. Lots of good information, some real craftsmen and engineers in this group.
Anyway I didn't want real long forks, the FEL make you be careful as it is.
I figured that with only about a 400 lb load limit for the FEL, carrying a load up to 3 feet further forward plus the weight of the forks would limit the load to about 300 lbs so I didn't have to build a battleship.
I dug around in my scrap pile, found a couple of pieces of 3" structural steel that someone had made some detachable side boards out of and a piece of flat plate and some metal straping about 1 1/2 X 1/8" and I even found a heavy truck spring that my son had removed from his truck, cut off the ends about 5" long for the tips of my forks.
I started yesterday evening about 4 PM and I now have a dandy set of forks for my bota. Just goes to prove that some folks trash turns out to be a bota owners treasure.
I have a cutoff saw, an ac/dc welder and a metal worker that shears, punches and bends(breaks), which saves a lot of time.
I even painted the forks orange before taking the photos.
   / POST YOUR PICTURES OF FORKS? #52
Mne are like that only the main iron [4" channel] is 15" under the bucket, held in place with a 3/8 bolt. Cost about $25 and just unloaded a bundle of 50 2x4x14'. All my Cub Cadet wanted. bcs
Well, I finally got around to posting a picture of my finished forks. Here it is. It is now adapted to fit the front loader bobtach. Bobtach is great and should be standard equipment for all FEL attachments. A bobtach adapter plate is easy to field fabricate with only a welder and a torch. No special drill bits and no critical hole alignment. Very forgiving.
The forks are pin type. The grid thing on the forks is a brush rake that I use when picking up tree limbs. It slides over the forks and has two clips that bolt to the rake and prevent the rake from sliding off the forks.
I added chain hooks to each side of the forks. The big guard at the top prevents stuff from falling on me.
Someday I will back my tractor up to the forks and see if I can make it also work with the Speeco quick hitch. If sssso I could put it on front or back in two minutes or less.
These fork are robust and could lift far more weight than the tractor is ballasted for.
It was a rewarding project.
side picture
photo showing clips
   / POST YOUR PICTURES OF FORKS? #56
Store bought, Katsco I believe and heavy in construction.
   / POST YOUR PICTURES OF FORKS? #57
These will work on the fel or the three point. They weight 195# and will hold together with a load that even the three point won't get more than 8" of the ground. Built forks out of 4" ship channel they are about 30" long if I remember correctly.
   / POST YOUR PICTURES OF FORKS? #58
I just built these over the last few weeks. They work on my loader and my 3PH. I have about $225 invested in this project. I bought a Millermatic 210 this fall and this project was my first welding project ever.
These forks are patterned after the JD pallet forks, but I had to make a few changes to accomodate the style of forks that I had.
picture 1
picture 2
picture 3
picture 4
picture 5
picture 6
picture 7
Steve
   / POST YOUR PICTURES OF FORKS? #59
Here's my little offering. 2x3" steel tubing 32" long. Total cost to build was around $150. These are on a JD2210.
   / POST YOUR PICTURES OF FORKS? #60
Here's mine using a pair of take-off's, made frame from square tubing and had brackets custom made at a local fab shop. I have the plans if anyone is interested.
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
JOHN DEERE 68 FEED CART (A52708)
JOHN DEERE 68 FEED...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2011 Kenworth T700 T/A Sleeper Cab Truck Tractor (A55973)
2011 Kenworth T700...
