Post your garden pictures and tricks here
   / Post your garden pictures and tricks here #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Thought that some of the little garden tricks and secrets might be best shared with the TBN community. If you have a garden picture or tip on how to grow bigger veggies or save work doing it then why not post it here for all to see.
I'll post a picture of the garden after the sweet corn starts to come up. The first planting was just put in the ground today.
For all you pepper lovers here's a trick that we have successfully used here at the Pine Ridge 7 Ranch. Peppers regardless of variety, red, green. yellow, they all like hot weather, the hotter the better. So when we put our plants in the ground we cut black visqueen 12" in squares. We then put a slit in the middle so we can set it over the planted pepper plant. We use a bit of soil to hold down the plastic, this keeps the wind from picking up a corner and blowing it away. The black plastic absorbs more heat from the sun quickly warming the soil underneath, more-so than the surrounding area and as a result the peppers quickly respond. Also, an added side benefit is the fact that the plastic keeps the weeds down so you'll need to do much less weeding around the plants themselves.
   / Post your garden pictures and tricks here #3
Hi Mike,
My Uncle Dave uses Garden Time fabric, probablly much the same as your stuff. It allows the moisture in but prevents weeds. Will get a picture shortly /forums/images/graemlins/grin.gif
Im not smart enough to use it yet /forums/images/graemlins/confused.gif
   / Post your garden pictures and tricks here #4
Hi Mike,
   / Post your garden pictures and tricks here #5
On a whim, because the weather was perfect on April 10th, I planted a little sweet corn. 10 rows, 75' long. Enough for us and 10 times if it does good. With-in a week, it got wet. No more planting. It's just now drying out enough for most garden corn. (Farmers have most of their field corn in around here) I got lucky. No severe cold weather for 5 weeks that NORMALY are here. It's around 14" on average. Had to thin it some after it was about 6". (Planted too heavy) Hoping for roasted corn on 4TH of July.
   / Post your garden pictures and tricks here #6
   / Post your garden pictures and tricks here #7
Cabbage crop is better than I've been doing in the past. (MAYBE I've finally learned how???) These are Flat Dutch, about 8", got 24. Also have some that should be monsters. They're about 3 weeks away yet.
   / Post your garden pictures and tricks here #8
   / Post your garden pictures and tricks here #9
And the final picture from the month of May, here's one of 48 tomato plants. Growing, great color, and loaded with green tomatoes already, but nobody gets even a green one 'till I get the first red one! These have been in since April 15th. (WAY early for here.)
Best tip I can give, plant your garden under a lucky star.
   / Post your garden pictures and tricks here #10
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2013 CAT 246C (A47477)
Ford 655C 2WD Cab Backhoe (A55218)
Ford 655C 2WD Cab...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
