post pounder
/ post pounder #1
6sunset6
Veteran Member
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I need to put in a deer fence. PHD requires to much fill around the posts. Posts need to be 7 feet high but top couple of feet can be light weight. So the cheapest way, maybe is to buy 14' 4x4 cut in half pound in and add light weight extention. Brings me to the post pounder. All the commercial ones are hugh to drive full size posts. I only need to drive a 7 footer 1 1/2 to 2 feet and a 4 x 4 at that. So thinking about building something. I see large weights and a hydraulic lift. Does anyone know how the hydraulic lift lets go? is it mechanical or does it just dump fluid back through the valve?
/ post pounder #3
The size of auger will determine the amount of fill. Get a smaller auger if you can find one.
/ post pounder #4
I used sharpened 3 inch round x 7ft posts and beat them in the ground with the bottom of my full loader bucket! just a thought! pends soils thought! Posts where from tsc for 3.50 per post
/ post pounder #5
Drill some small, 6 or 9 inch, holes and then use pea gravel to back fill them instead of tamping with dirt. They'll be set almost as hard as if you put sackcrete in the holes.
JCB 3TS-8T TELESKID (A65053)
JCB 3TS-8T...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A64553)
2007 JLG 600HJ...
1995 CATERPILLAR 140G MOTOR GRADER (A65053)
1995 CATERPILLAR...
