Post pics of your two wheeler
   / Post pics of your two wheeler #2
Here's a few of mine hooked to a trailer with another project on board. Last two pics are the gas tank after I moved it to the front of engine, away from muffler, had trouble with vapor lock during hot weather this summer and Joel at Earth Tools suggested 100LL AV gas, this was easier solution. Last pic is with the tank in original position, and before paint and new decal from Earth Tools, Joel is a gold mine when it comes to these machines.
   / Post pics of your two wheeler #3
Here is my homemade wheelbarrow attachment. I keep the grass down around my place with the 31" brush hog from Joel at Earthtools, works well, I have run over some hidden rocks and stumps, and have not destroyed it yet. The BCS has worked out well, I can get under all the oak trees, and mow some steep slopes without any problems.
Both very cool BCS machines.
Bentworker, what tires do you have for your BCS. They look very nice?
   / Post pics of your two wheeler #5
Here are some pics of my Gravely with a 40" mower. When I change implements I'll take more pic's.
Solo
Thanks, I'll check the store out. Those tires look like they will come in handy.
   / Post pics of your two wheeler #8
I bought a receiver like you have on your bucket at Farm/Fleet, looks like it would work great.. I dont have it welded or bolted yet, but soon, I have a clamp on one and it moves too easy while under load.. You think you have an original idea, stick around a while, somebody already did it.. :)
I got the idea for the reciever from reading these forums. I think just about everything has been thought of already.
It does work well. Since I'm not much of a welder, I just drilled some holes and bolted it right up. Only took a few minutes to do and now I can move the trailers around really easy.
   / Post pics of your two wheeler #10
Bentworker said:
The bigger tires help out a lot with the mower, it got the engine up out of the way so I can actually drive it across a ditch without getting stuck.
Interesting...I've a similar problem with my 853 with the sickle bar when cutting in a ditch.
But...how much do they increase ground speed? I use second gear when mowing, and it's a comfortable walking speed. Do you have to jog to keep up? :D
And, I keep it in low gear when tilling...can't imagine going much faster than it does with the stock tires, but that probably depends a lot on ground conditions.
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
IH 1566 Tractor (A50514)
IH 1566 Tractor...
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
2008 CATERPILLAR 140M VHP MOTORGRADER (A51242)
2008 CATERPILLAR...
2002 Wilson Hopper Bottom Trailer (A50514)
2002 Wilson Hopper...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
