Post Hole Diggers
/ Post Hole Diggers #1
ERNIEB
Platinum Member
Saint Hedwig, TX
TC29D, 8n, 9n
After I got my tractor, one of my first additions was a post hole digger. Like most people , I guess, I don't use it much, but when needed it comes in really handy. Not knowing much about them I went to the dealer, and he suggested the Land Pride PD 15, He mentioned the down pressure kit, but with the cost of that and adding on rear hydraulic couplings, no more than I would be using it, he didn't think the kit was necessary. Well I've had a chance to use it a few times and seem to have a problem. Here on my ground I have a layer of sand that runs about 12 to 24 inches in most places. Then you hit a layer of clay that is very compacted. when it get to the clay, the downward movment all but stops. I've left it running for about an hour and it only went down about 1/4 to 1/2 in. I've tried adding a little downward pressure in various ways , which helps, but is not that effective. The tip of the auger looks like it can be changed, would that help? Can these tips be sharpened? I'm open to any other ideas.
/ Post Hole Diggers #2
Know whut ya mean. I have Bush Hog brand digger with 9" & 12" auger. Very poor performance at times depending on soil condition. We have some clay in Mid TN. too. I took 2 old Allis Chalmers rear wheel weights (115# each) and mounted them on a crossbar I welded on the backbone of digger. Welded it right where the top of the arch is. Helped a lot. $2 worth steel, $30 (old, used)worth weights. Of course keeping the point sharp and those bolt on digger,breaker up thingies at the end of flutes in good shape is a must.
I have heard of a lot of people having the same poor performance and applying down pressure by some other means as you mention. How did you do it. Just know diggers are VERY DANGEROUS. They can grab your clothing and wrap you up in an instant. Ripping off hands, feet, arms,legs, etc. before a cat can lick his uhhhh well.
I have lusted after the hydraulic down pressure diggers but have not priced them. I believe I know what the answer is. $$$$$$$ You be careful I hear horror stories each year about digger accidents.
/ Post Hole Diggers
Wow, I was beganing to think I was the only person on here with a post hole digger, or at least the only one with hard soil. Things I've tried. Once I needed a hole near two mesquite trees. I hooked a come along to the base of one tree ran the cable thru the yoke thing on top of the gear box(not sure what the name for that is) and then down to the base of the other tree. As it dug I cranked down on the come along. Worked great, but most times two trees are not available. Another trick was using a heavy digging bar with a flat end that I would stick in the yoke thing, then just sit down on the bar. It helps but not all that much.
I like the wheel weight idea. Do You have any trouble hooking up or unhooking? Do you do the sharping Yourself?
I looked at one hydraulic type that looked like a stand with an auger thru the center. You just drop the thing down and bingo, you get a straight hole every time. Price tag was 2 to 3 Gs.
Yea, they are a dangerous device, which I guess is what started me to wondering how others deal with the problem. One story I've heard is that somehow the thing swings over and comes down on the operator seat and consequently the operator if he's seated there. I don't see how this could happen but it's what I've heard. Anyway thanks for the comments and idea.
ErnieB
/ Post Hole Diggers #4
I just got a hydraulic downforce kit for my Danuser F8. It's supposed to put 500 lb of downforce on the auger. I haven't installed it yet, but hope to try it out on a big project I've got coming up next week. I'll let you know. Cost was about $450.
Do you remember where you saw the hydraulic auger you mentioned? I've seen hydraulic augers before, but not like the one you described.
I've heard all kinds of stories about accidents with augers and even met a man who lost both arms to an auger accident, but I've never heard of one coming back on the operator sitting in the seat. I don't really see how that could happen, either.
MarkC
/ Post Hole Diggers
MarkC, for the down pressure kit and the rear couplings my dealer told me it would run about $500. According to Land pride it suppose to put 500 lbs down. So do let me know how it works, I'd really like your opinion.
I don't recall the name of the thing, but it was at Greater Southwest Equipment in San Antonio. they handle Kubota, Case/IH, MF, and several diferent brands of equipment. They seem to be geared to the commercial/contractor market.
ErnieB
/ Post Hole Diggers #6
I use a 3pt auger w/o downpressure. Yes the cutting tips can and should be kept sharp but not like a knife edge, more like the rotary cutter blade. One thing I did find out if going through grass before you hit the dirt is the grass winds around the auger tip and GREATLY reduces the effectiveness. the longer the grass the worse it is. If you're going through grass first as soon as you hit dirt bring the auger back up and remove all the grass from the auger, then drop back into the hole. Makes a world of difference. The only thing I could see a down kit needed for is rocky soil. The auger should bite right through hard clay. Are you sure you don't have some rocks down there too?? I've done some holes in less than 5 minutes (9 inch auger 3 ft deep) and others I had to move the hole due to the rocks being to big.
/ Post Hole Diggers
Gerard, there is a little sandstone scattered around, but it's not much and it's pretty soft. I've started some holes that went about 12 inches of sand and then about 12 inches of clay, and filled the holes with water and let them sit overnight. The next morning, the water had penetrated about 3 inches. Another thing, the material coming out of the hole, is very fine, like brown talcum powder in fact. So I wonder if the tip is my problem. I've put in T posts without trouble. And just as a note, A lot of people around me just dig through the sand to put a post in. Yep, there is alot of fence falling down around here/w3tcompact/icons/wink.gif.
ErnieB
/ Post Hole Diggers #8
Ernie:
I bought my 9" Posthole digger used and it had been modified to leverage the digger into the ground. A 12" piece of 3.5" heavy wall pipe has been welded to the topside of the Top-Link Arm that holds the Gearbox. A second person inserts a 10-Foot of 2.25" pipe into this and pulls down while running the auger. I recently drilled 10 holes in this Texas (Concrete) clay in about 5 Minutes each. By the way the tip can be removed and sharpened, I did this with a 4.5" Grinder.
Chuck
<P ID="edit"><FONT SIZE=-1>Edited by chuckp on 10/9/00 00:40 AM.</FONT></P>
/ Post Hole Diggers #9
chuckp, I helped a neighbor do the same thing to his old posthole digger. And if you don't have a second person to get on the end of the pipe, he has two 75# sash weights he can hang out on the end of the pipe. Works great.
Bird
/ Post Hole Diggers #10
Our ground is hard clay, with a fair amount of rock thrown in for bad measure.
I have found it is most helpful to have a jack hammer around to supplement a auger. I have used Makita and Bosch electric units with good success. When we put in a fenced yard for my son, out of 18 holes, 9 of them would only auger about 3" deep. Another trip to the rental yard for a jack hammer...
RobertN in Shingle Springs Calif
/ Post Hole Diggers #11
Sounds like the pipe solution might be as good as a down pressure kit at next to no cost, great idea! Does your auger have a screw point and then the flighting has two removable/replacebale/sharpenable blades? Thats what I have and it works fine in anything but solid rock. You must have some really hard clay out your way, glad I dont! /w3tcompact/icons/smile.gif
/ Post Hole Diggers #12
What is the cost on a good used one. When an auction this weekend and they had one that seemed to go very high.
/ Post Hole Diggers #13
got to tell you in clay add water no hose use a big bucket pour it in the hole then yell yeehaa
/ Post Hole Diggers #14
Recently, I too have experienced the "non digging" auger. In my case it is a Befco M2 9" auger without any downforce kit. I've become very suspicious of the replacable auger point. As a test, I removed the auger point and I was able to dig down another 6" right away (until the middle was so compacted with dirt it stopped). I don't think that my auger point is a very good design. It looks kinda like a large wood screw. However the threads of this screw are very wide, in some places over .5" thick. These thick threads (and the blunt tip) really cut down on the downward pressure that the auger can generate. It's not much different than trying to push a smooth cone shape (point first) into the ground. I'm going to see if I can modify the auger point so that I can put some sort of replacable cutting edge on it. Maybe two flights bolted onto the tip at angles...
Peter
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
DOBBS 48in Forks and Frame Skid Steer Attachment (A61572)
DOBBS 48in Forks...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
