Post Hole Digger
/ Post Hole Digger #1
Soggy Bottom Outdoors
Brandenburg ky
2013 john deere 5075E and others
I bought a Farm Star PHD new and planed on using it on a 8N. To do so I needed to shorten/cut the pto shaft to give it a full range of motion. Well I traded the 8N to a MF and now the shaft is to short in the raised position. Where can I find a short peice of shaft tubing, a foot or so, to lengthen it back out. It's the "triangle" style which is called something else because a internet search came up blank. I thought I saw some at TSC/Orscheln but the last couple times I've checked they had none. Don't need a complete shaft half, just some tubing.
/ Post Hole Digger #2
Check the local tractor dealer. In most cases, they will carry the replacement tubing.
/ Post Hole Digger #5
Is there any way that you could keep and use the long auger? I bet you could find a way to work around the length issue and be glad that you have the extra length.
/ Post Hole Digger #6
This being an older thread I was just wondering if the problem had been resolved ??
my thought was a welding shop could add to the solid shaft instead of the tubing ??
just my 2 cents.
Mike
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2017 Hyundai Trailer (A62613)
2017 Hyundai...
1500 gal Poly Tank (A66408)
1500 gal Poly Tank...
Deutz D3006 Tractor (A62613)
Deutz D3006...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
