Post Hole Digger???
/ Post Hole Digger??? #11
J_J said:
The data below is for a hydraulic PHD.
Let me jump in here and offer some advise/suggestions. If you can weld, put some hard surface on the cutting edges.
The valve below will do what you want. It is a double acting valve, with forward and reverse and can handle all the fluid the PTO can run through it. It is spring centered, but a hold down strap or rod, will hold it in the fwd direction. You might be able to find a motor spool valve with detent in the fwd direction. It can be mounted after the PTO, and left in place. Knowledge is power.
Surplus Center Item Detail
Thanks for that link, I was just getting ready to look for one of those reversers.
/ Post Hole Digger??? #12
So have we pretty much established that the motors used on PT attachments are reversible? I think I remember some discussion about that a long time ago.
/ Post Hole Digger??? #13
You have to make sure. As I recall, some are and some aren't.
/ Post Hole Digger??? #14
I have the tiller. I just reversed the lines because the way they set it up, it keeps jamming up with rocks.
I reversed all the tines, I ran it, but haven't put it in the dirt yet....just mud here now.
/ Post Hole Digger??? #15
Can you show us a picture of the reverse tines, and which direction it will be turning.
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
