Posthole Digger Post Hole digger won't go deep enough???
   / Post Hole digger won't go deep enough??? #11
Re: Post Hole digger won\'t go deep enough???
Ron
Yes I was able to lift it high enough, but what I did was start each hole with the unextended auger as I felt I had better control, add the extension when at max depth. Adding the extension was quite simple and only took a few minutes. Using pins would be quicker. As can be seen in the pic, the spoils were something of balled up clay and I had to help them out using a narror trench spade, even the unextended auger would not spew them out and away.
David
   / Post Hole digger won't go deep enough??? #12
ProjectX
Great. Perhaps you can make it adjustable for use at either 12 or 8?
David
When I had it built, I left a lot of room to modify it. When I drilled and reamed the holes for the pins, I left if at full length of the large diameter shaft (18"). I could cut it shorter, or use smaller diameter shaft closer to the end which would extend it another 8". It worked great, but I'm going probably settle on 10"-12" which I could extend another 8" longer if need be.
Cheers,
Rob
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
2007 JLG SkyTrak 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
CUSTOM TRAILER (A51242)
CUSTOM TRAILER...
2016 GMC Sierra 1500 SLT (A50323)
2016 GMC Sierra...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2020 Kenworth T880 Tandem Axle Day Cab Road Tractor (A47384)
2020 Kenworth T880...
