Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #1
JD 4520
Platinum Member
Snohomish County WA
John Deere 4520
Recently purchased a down pressure kit to fit my PHD. Both Frontier products from Deere. The installation of the HDP is straight forward except for the return line to the hydraulic tank. Naturally there was no instructions included. The dealer (Washington Tractor) hasn't yet been helpful with instructions or how or where to connect this line.
I have a JD 4520 Compact.
I have identified a plug on the upper portion of transmission that appears that I could remove the plug and tap into the reserve there. That is just a thought.
Any ideas?
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #2
Any ideas?
That should be the right spot. That is where my 4th and 5th SCV tank port goes on my 2012 4720, and the power beyond tank port. Here is a parts breakdown of the power beyond. You can see the main parts 23, 7, 14, 15 plus the misc. o-rings. That would get you the quick connect, and all.
  • Power beyond.pdf
Thanks for this recommendation. If you could post a close up picture, that would be most helpful to me.
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #4
Ask and you shall receive. From 2 different angles.
Isn't technology great. Thank you. I am on the right track.
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #6
I can't wait till we all just have chips plugged into our heads:laughing:
I found the parts today to make the connection. Should have it running this weekend. Thanks again for the tips.
Related question; I installed the down pressure kit (it is a single acting cylinder) and connected the pressure line to the 3rd SCV and return line to the tank. When I enact the SCV lever it supplies the pressure to expand the cylinder. How does it retract? This seems kind of a silly question but the logic of double acting cylinders are much more straight forward than single acting cylinders.
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #9
You raise the hitch, it collapses the cylinder forcing the fluid out and to the return line.
UPDATE: I installed the down pressure kit. It installed reasonably easy other than I had to go to the hydraulic store to get several fittings to complete the installation. It doesn't work properly. The hydraulic extends fine but does not contract. I have trouble shot it and determined that the only way to relieve the pressure in order to contract the cylinder is to remove the pressure reducer. It doesn't make sense. Any thoughts on what I might be doing wrong?
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #11
Assuming that you now have everything plumbed per the directions?:confused3: The cylinder will not retract on it's own. It should collapse when the PHD is raised. The 3pt has more strength than what the pressure bypass has and allows the cylinder to retract. The cylinder only adds pressure. Because of the pressure bypass valve, it is not locked solid like a std cylinder would be when the control valve is in neutral.
If you remove the pressure bypass, you will have other problems to contend with. DO NOT remove the bypass valve. ;)
Assuming that you now have everything plumbed per the directions?:confused3: The cylinder will not retract on it's own. It should collapse when the PHD is raised. The 3pt has more strength than what the pressure bypass has and allows the cylinder to retract. The cylinder only adds pressure. Because of the pressure bypass valve, it is not locked solid like a std cylinder would be when the control valve is in neutral. If you remove the pressure bypass, you will have other problems to contend with. DO NOT remove the bypass valve. ;)
Yes, I do have everything plumbed per the directions whereby the pressure is running off of my 3rd SCV. I have not been able to get the cylinder to collapse on its own. I have had to lessen a fitting to relieve pressure in order to get it to collapse. It seems to me that the pressure bypass is not properly working or it would allow for the pressure to do as you state and the cylinder to retract. Could anything else be wrong in this situation?
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #13
Is that cyl an SA cyl with one hose or a DA cyl with two ports and two hoses?
An SA cyl needs weight to retract, either pushing or pulling..
Show pic of your down pressure kit.
What pressure bypass are you talking about?
If your DA valve controls the cyl, one direction of the lever will extend the cyl, and the other direction will release the fluid and cause the valve to go into relief. One work port should be plugged, or a hose from that work port should go to tank.
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #14
So have you tried to raise the PHD and it will not raise? I guess that I don't understand how it is that you know that the relief is not working? You are not going to collapse the cylinder by hand. Sorry for the questions, just trying to understand what all you have done. :confused3:
Is that cyl an SA cyl with one hose or a DA cyl with two ports and two hoses? An SA cyl needs weight to retract, either pushing or pulling.. Show pic of your down pressure kit. What pressure bypass are you talking about? If your DA valve controls the cyl, one direction of the lever will extend the cyl, and the other direction will release the fluid and cause the valve to go into relief. One work port should be plugged, or a hose from that work port should go to tank.
I will get pictures later today as that may help. It is a single.
Yes I have tried and it will not collapse. I cannot collapse it by hand either. Only way to collapse it to remove the valve. I tried to collapse it by removing the lines to see if there was anything to do with the lines or connectors but still would not collapse. It is like it's holding the pressure.
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #17
You should not be able to collapse it by hand. Is the relief valve adjustable? If so, it is set too high.
image-235636287.jpg image-1829757226.jpg Pictures do help. I removed the cylinder from the PHD since it easily detaches with a couple of pins. I will attempt to adjust the tension. Instructions tell you how but warn not to.
   / Post Hole Digger (PHD) Hydraulic Down Pressure (HDP) Kit Installation #19
If the SA cyl provides down pressure, does the cyl not retract by raising the 3pt.
One of the other manufacturer suggested that you need a float valve to operate the unit.
If the SA cyl provides down pressure, does the cyl not retract by raising the 3pt. One of the other manufacturer suggested that you need a float valve to operate the unit.
The SA cylinder does not retract when raising the 3 PT. I may need to check into the float valve idea.
2023 CATERPILLAR 120 MOTORGRADER (A60429)
2023 CATERPILLAR...
UNUSED FUTURE 100YG PIPE GRIPPING MACHINE (A60432)
UNUSED FUTURE...
Ratchet Straps (A59230)
Ratchet Straps...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
