Posthole Digger Post Hole Digger on cat 0
   / Post Hole Digger on cat 0 #1
Anonymous Poster
Epic Contributor
Does anyone have experience with post-hole diggers (augers) on a cat 0 hitch. I'm looking at a John Deere 445 which has a cat 0 hitch and a 540rpm rear PTO option. One place I looked at which had some potential was:
http://www.worksaver.com/product/phd-ut.html
What do y'all think?
   / Post Hole Digger on cat 0 #2
Augie,
My GENERAL, UNEDUCATED impression is that maybe it would be okay.../w3tcompact/icons/shocked.gif
It really depends on what kind of soil you are digging into and what size of auger you have on the unit. In loose, sandy soil, with a 6" or 9" auger, providing that you keep moving the auger in & out to clear it, it would probably go okay. In hard, rocky, mountainous soil, forget it - rent a unit instead. I think the best advice I could provide would be to remember that it's a smaller tractor - it will take longer to dig a hole. If you are trying to run it 8 hrs a day, contracting to get so many holes dug . . . I'd be concerned about the unit (and my tractor!) lasting for very long.
hth,
Dave Wells
   / Post Hole Digger on cat 0 #3
Most small post hole diggers are category 1. You will need to measure the max width of your lift arms and those of your digger. It would be best to see if the digger will fit on your tractor before you buy. I dont know if any one makes a category 0 digger. I have used a category 1 digger on a 16hp kubota B1700 in dirt and clay type soils. It does work but need to dig slowly and raise frequently to clean out the dirt or the tractor might not be able to lift the digger. Dont let the digger go in too fast and bury itself. If you have rocks or tree roots you may not be happy. Remember if the digger gets stuck and can't be lifted out, use a pipe wrench to reverse the direction of the auger and screw the auger out backwards.
I bought a shaver 101 which is cat. 0 over the internet from eastern farm machinery it works fine for the 30 of so holes I dig each year.
   / Post Hole Digger on cat 0 #5
fjohnson:
How far are you from eastern farm machinery? Didn't the shipping cost just eat you up?
I ask because I wonder about buying implements over the internet....
I also bought a backhoe so the shipping included both pieces it was $330.00 I saved about $1200 from the "local" quotes I received. I guess the shipping wouldn't have been worthwhile if I had just bought the post hole auger, but I'm not really sure.
gps trailers (A56859)
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
2017 Freightliner Bucket Truck (A55973)
2017 Freightliner...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
LOT: (1) Shelf of Takeuchi & Donaldson Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (1) Shelf of...
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
