Post Hole Digger - if stuck
/ Post Hole Digger - if stuck #41
I am very impressed with the Danuser 8300. Here is their responce to my question regarding speed at only 5 gal/min. Most run too slow at 5gal/min.
The 8300-1 at 5 GPM will have a RPM of 47.
Glenn Danuser
sales@danuser.com
Danuser Machine Company, Inc.
500 East Third Street
Fulton, MO 65251
573.642.2246 PH
573.642.2240 FX
Welcome to Danuser Machine Company
/ Post Hole Digger - if stuck #43
Here is a link to a 5-10 gallon Mcmillen phd.
McMillen
/ Post Hole Digger - if stuck #44
3RRL said:
Jerry,
How does that Danuser compare price wise?
Thanks,
I don't know what the prices are right now. They are not an economy line, but they are less expensive than Belltech. What I can say is that everything that they have is designed to last and they stand behind their equipment very well.
/ Post Hole Digger - if stuck #45
The Gardener said:
What prevents a tractor PTO from having a reverse? Is it simply impossible to design? I ask because that would certainly eliminate most of the concerns rearding a Post Hole Digger becoming stuck.
My late FIL's 430 Case didn't have an independent PTO, as a result the PTO shaft turned whichever direction the gear shift indicated. The tractor has a lever to place the tractor into netural to allow you to use the PTO without the tractor moving. This was really handy with a PHD. You could dig at a variety of speeds and have reverse to back the PHD out of holes.
/ Post Hole Digger - if stuck #46
My B-I-L and I got his stuck over the weekend in some rocks. Of course it was all the way down. Howwever, it really isn't that hard to back it out with a pipe wrench. It only took about 3 reverse turns to get it loose enough to come out. It took longer to take the auger off and put it back on. So fo for me, I think I'll just get a basic one (one day) and reverse it out by hand when needed.
Here is a question though, why doesn't anyone put a reverse gear on the gear box of the PHD? I realize it would be bigger and more expensive...and maybe not as durable. But it sure would be nice and still a lot less expensive than a hydro unit.
/ Post Hole Digger - if stuck #47
Early last year I dug over 5000 holes with a cheapo Leinbach 7400 and 12" auger. After getting tired of breaking shear bolts, I added an inline slip clutch. I never came close to getting it stuck, but I did make a mistake by tightening up the slip clutch when I kept smoking it. I ended up twisting the 12" auger in half. :eek: :eek:
Honestly, if you keep a close watch on the auger and one hand on the 3 pt. lever, you can pull up every so often and almost never get it stuck. As I mentioned, I was zero stuck in over 5000 tries. With a decent cutting edge on the auger I never felt the need for any down force at all either.
I've used a skid steer with a front auger before and it worked fine. But, as someone else mentioned, how could you see your auger with the tractor hood in the way? I spray painted a line on my auger so I'd know when to stop at the depth I needed. If it were in front of my tractor I couldn't see when to stop nor could I see very easily when it started to bite in too hard. It looks like a nice setup that way, but I'd be afraid of not being able to see the auger.
/ Post Hole Digger - if stuck #48
Please excuse my ignorance but how do you get a PHD stuck? I have used mine (with the 12 inch auger mostly) off and on for 5 years and have sometimes had trouble getting a hole started but never got the auger stuck. I use full down control on the 3PH to dig and anytime I pull the 3PH up the auger comes up. Dumb luck I'm sure as I never had instruction on using a PHD.
Pat
/ Post Hole Digger - if stuck #49
It usually happens with a smaller auger, like a 9" one, but the auger basically screws itself into the ground rather than dig a hole. If you use a smaller auger and slow speed in good heavy clay soil you can get it to happen without much trouble. ;)
/ Post Hole Digger - if stuck #50
If he had room to get at the bolts to remove the auger, could he have left it on and just used the pipe wrench with the pto off? Thats what I've done and it worked well and was quick. I didn't need a huge wrench either. It took longer to go get the wrench than to use it.
/ Post Hole Digger - if stuck #51
As with many things on this board, many of us have very different experiences because of the different areas that we work in.
We get the PHD stuck occassionally, while not "often" it happens often enough that we need a way to easily get "unstuck"
Anyway, to the question of "how"
Most often we will pick up the edge of a good sized root and the auger will screw on down, now the root (sometimes a rock edge) is over the flight of the auger and it will not want to come back up...
Catch between two roots, one on each side of the shaft,, and cussing is about to start.
I will caveat that we also almost always have the 18" auger on our PHD but I believe I have gotten them all stuck at some point. (well, maybe not the 6")
I will say though that I never have taken the auger off the phd that I can remember, slight up pressure with the tractor and unscrew it.
/ Post Hole Digger - if stuck #52
I second that Alanb. Thats how I do it also.
To own multiple diameters, do you buy one auger [PHD] and then you just buy various size diameter bits that are interchangeable?
Concerning the various sizes [6", 9", 12", 18", 24", etc.], are there specific sizes for specific jobs [typically speaking]?
I would be using our auger for fence posts almost exclusively. However, I could see using it for planting small trees and bushes by, perhaps, making several holes in a cluster to enlarge the hole to the correct /needed size.
I was thinking that the 12" diameter is probably a good match for fence posts.
Thanks,
The Gardener
/ Post Hole Digger - if stuck #54
Depends on the posts that you are using and how big a hole you want, you may want a lot of concrete around them, or maybe you just want a starter hole for a chainlink fence post.
Yes, I have one PHD and multiple augers, you have to watch your mount bolt configuration, there is one pretty common one, that has two cross bolts one above the other at right angles to each other, but there are several others others out there as well. There are also different shafts on the PHD.
There are adapters made, and can be locally fabricated pretty easily, but if you are doing a limited amount of drilling, it would be more straight forward if you had the "common" one. (not really sure what it is called, but it is the one that TSC carries)
We mostly use the 18" but it is 90% of the time used for putting in plants. As you said, when we do tree's, we will drill 3 or 4 holes with the 18" and hand dig between them.
I am about to set some RR ties as fence posts, and will not be concreting them in, so will use the 12" to dig the holes.
/ Post Hole Digger - if stuck #56
Thanks for the warning. I also have a smaller auger that I have never put on the PHD in 5 years of use. It is either a 6 or 9 inch. I'll be careful.
I wonder what would happen if I put a metal bar or wooden 4x4 sideways to prevent the gear box from being sucked below the surface and let the small diameter auger screw into the ground. I'd think it might "strip the threads" formed in the dirt and release it.
I usually dig a little and then retract the auger till the tip is about at the surface and then go again and don't try to dig the full depth all at one time.
I have had the experience of drilling into copper and lead and having the bit thread itself into the metal. I found out that there is a different angle required on the bit for these soft metals.
Pat
/ Post Hole Digger - if stuck #57
Charlesaf3 said:
I'll post a review of it after I've used it for a while.
Have you had a chance to use the auger much? I am looking forward to your review.
/ Post Hole Digger - if stuck #58
I also express my thanks for the warning. My 12" auger has had a workout, but the 9" has been a total "barn queen".
As far as "strip(ping) the threads" is concerned, I think that would be determined by soil conditions, the maximum torque available from the PTO, and whether or not the PHD gearing could absorb the required torque without stripping a gear or shear pin - assuming the auger itself didn't fail.
I always watch the auger very closely and, occasionally, have noticed it suddenly assume a much faster sink rate. So far, I've been able to stop it soon enough that the 3pt could lift the PHD and "strip the (1 or 2) threads". I hope I remain that lucky since I don't think my setup would survive the proposed solution to a full blown "auger down" incident.
/ Post Hole Digger - if stuck #59
Pat,
What you are doing, clearing it after some depth but not all the way is a good thing and recommended. As far as wondering if yours will strip the dirt threads if you put a wooden block or something down, I don't think so unless it's very sandy. I think your shear bolt would give before that.
Mine is a Ø12" auger and I try to set the position control so it can only work its way down no more than a foot at a time. You can tell the difference when it is "cutting" and screwing itself in. I've had shear bolts pop even after only 1 foot depth of "screw in" if that happens.
/ Post Hole Digger - if stuck #60
3RRL and Tom V, I guess I must have just been lucky to have started out doing whatever it was that prevents my ever sticking an auger (so far.) I have used it a considerable number of times in 5+ years and did shear the soft shear bolts one time when I was over enthusiastic when I first got it.
Who knows I may eventually find a use for the 9 inch.
I have 40HP to the PTO and the PHD is rated for more so that is a good thing since I don't know what I am doing with it a lot of the time and have to proceed with brute force and awkwardness. This stuff doesn't lend itself so easily to clear concepts like true flight path elevation angle (alpha) and angle of attack (beta.) (Waxing professorial for Tom.)
Pat
New/Unused Wolverine 78in Quick Attach Rock Bucket (A65583)
New/Unused...
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
2006 Honda Accord Sedan (A64557)
2006 Honda Accord...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
Toro LX460 Riding Mower (A65579)
Toro LX460 Riding...
