post hole digger for Max 25
   / post hole digger for Max 25 #1
garye5007
Glastonbury, Ct
Mahindra Max 25
I am looking around for a used PHD for my Max 25
seen a few on craigs list, but I dont know how to be sure it will fit? I cant bring machine to try. the thing I worry most about is if it will lift high enough for auger to clear ground. I plan to dig 6" holes for fencing.
Any advice would be GREATLY appreciated!
Thanks
   / post hole digger for Max 25 #2
if it's a cat1 PHD it should be fine. clearance wasn't an issue on my 28 but I think it had bigger wheels and tires than the 25 does, either way you should be good.
Thanks for the fast reply!
theres a Danuser f7 here for $600 I called Danuser and they say 40 HP is this a problem with a 6' auger?
also a JD for $500
   / post hole digger for Max 25 #4
We make PHDs just for subcompact tractors like the Mahindra Maxx, Kubota BX and 1000 Series JDs. If the phd is made for a compact or utility tractor, chances are you'll be dragging the auger around due to the limited lift height.
Post Hole Digger for Compact Tractors.
Free shipping to your home within 1,000 miles of Newton, NC.
Something to keep in mind with used PHDs is parts availability....auger teeth/tips(danuser is no issue) and the cost of parts. Some older phds have odd sized output shafts, so replacement augers are impossible to find.
Travis
   / post hole digger for Max 25 #5
No problems here running a standard Cat 1 PHD on my Max 25. I have put in over 75 fence posts with it so far. Never comes close to dragging and HP was definitely NOT an issue.
1268 (A50490)
1268 (A50490)
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
