Post Hole Digger for BX Series
/ Post Hole Digger for BX Series #1
Barryh
Veteran Member
Harpers Ferry WV - Mountains of Shannondale
Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
Was wondering if anyone has had any experience good or bad with this little bugger? Thinking about picking one up next month. The shorter auger looks like it could be a real winner on my BX-1500. Thanks for any feedback. :eek:
Land Pride PD10 Post Hole Diggers
/ Post Hole Digger for BX Series #2
There is a thread here where some doubts are raised about using a PD10 with a BX1500.
Thanks will have to do some more research on the 3 point. I can't imagine power is an issue, most reports I've read using a digger with any BX, it bores barely off idle. Thanks for the feed back just the same.;)
/ Post Hole Digger for BX Series #4
I use a Vassar (made in Oklahoma I think) PHD on my BX2200. Power has NEVER been an issue and I dig in hard clay. I run mine barely above idle and it's no problem. Once in awhile, if I hook a root, it will kill the tractor before it shears the bolt.
The issue I DO have with the combination is I can't twist enough to see how the auger is aligning to the hole. It sits so close to the tractor. Also, due to this closeness, It is almost a requirement to reposition the tractor as the auger goes down as the angle changes otherwise.
The biggest issue I have is that I've found it is much easier to dig a PH with TWO people, one standing on each side of the platform. It takes quite a contortionist to be able to engage the PTO with the left hand, operate the 3PH with the right, all while crimping your neck 180 degrees to the rear.
When we have several holes to dig, I get someone on the right to run the 3PH and I operate the PTO. While not safe, you COULD cheat and engage the seat belt, then use your hands controlling the HST to roll the Bota forward as the hole goes down to keep the hole perpendicular. Of course, this wouldn't be safe, so I don't do it, probably.............
ron
ron
Hmmmm sounds like a real pain without some help :confused: do you have or need a down pressure kit for yours? We have hard packed red clay, shale and rock around here. I'm guessing it could be a problem with a large Auger bit. Thinking 9 inch?
/ Post Hole Digger for BX Series #6
I have a Woods PHD 25 with a short 9" auger for my BX2200 and as previously stated power hasn't been a problem. I don't have down pressure and that hasn't been a problem, in fact, I have to take care that the auger doesn't screw itself into the ground. I don't put the lift all the way down at once. I'm satisfied with the performance of the PHD on my BX. Good luck!
/ Post Hole Digger for BX Series #7
I have that exact one. I use it on my BX2350 last somer to plant trees and shrubs (no backhoe and regret that). I've had very little problems with it and can't wait to drill some more. One thing I noticed, is you want to "pull out" a lot to prevent it from digging to China. I almost got it stuck once because it wrapped right around a rock. My whole property is loaded with potato sized rocks.
If you have a lot of clay, maybe power would be an issue.
Scott (Frostyford)
/ Post Hole Digger for BX Series #8
The LP PHD10 should be perfect for the BX1500. I run a full sized PHD on my BX2200. The PHD10 is a nice small unit and would match the BX1500 well.
Land Pride does sell a downpressure kit for that series. It isn't recommended by LP for the Model 10 (only model 15 and higher), however it can be put on. TBN member ultrarunner has the LP PHD10 and downpressure unit on his BX23. You would likely not need the downpressure unit unless you have hardpan. I think LP provides a Pengo auger with this PHD. Pengo augers are available with a variety of very agressive bit tips for differing types of soils, hardpans, and even rock.
I was at the Kubota dealer this week and saw a Gearmore sub-compact PHD Model D20 on a BX2350. Gearmore also provides Pengo augers and tips. It was about the same size as the LP PHD10. It was obvious that the BX2350 could take a bigger unit and that this little Gearmore would be more appropriate for a BX1500.
Gearmore mainly sells in the west, but does sell some things nationally, so don't know how easily available this unit would be in WV.
BTW, regardless of whether you went with LP or Gearmore, you can actually choose an alternate auger and tips from Pengo. Give them a look at:
Pengo
Pengo
Hey, thanks for the info from all of you guys, it's greatly appreciated. Also if anyone with a 1500 has any of these units I would be interested in hearing about your experiences first hand. :eek:
/ Post Hole Digger for BX Series #10
Barryh,
Have a read through the thread below. I think it may give you a higher confidence in the abilities of your tractor. blackmajicwoman put a Woods BH6000 backhoe on his BX1500. Take a look at the trenches he dug and the stumps he pulled. Now it is true that I have not personally run a sub-compact PHD on a BX1500. In my own mind, I think that if my BX2200 can run a full sized PHD, ultrarunner's BX23 with LP PD10 and downpressure unit drills in serpentine rock with little effort, and blackmajicwoman can do this extensive backhoe work with a BX1500, I have a strong confidence that the BX1500 should have no trouble running a LP PD10 or Gearmore D20 in the soil you describe.
Again, I have not seen the combo, but hopefully these facts can ease your mind about the decision you are trying to make. It is your money, and I understand well not wanting to buy something when you aren't sure it will work. I myself have duripan-the hardest hardpan there is. Shovels and prybars just bounce off it, even when it's had water sitting on it for weeks. I debated for years as to whether a BX with backhoe could dig in it. A TBN neighbor, BX23Barry, brought his tractor over recently, and it did indeed dig in the stuff. That relieved my mind enough to order a Woods BH6000 for my BX2200. So, I agree with your caution. blackmajicwoman has other threads re. his BX1500. You can find those and posts by ultrarunner by using the search function. I hope this extra information is helpful as you try to make the best decision. Here's the main thread with blackmajicwoman's BX1500 and the Woods BH6000 backhoe:
http://www.tractorbynet.com/forums/...500-woods-bh6000.html?highlight=BX1500+BH6000
/ Post Hole Digger for BX Series #11
Barry,
Mine doesn't have down pressure. Mine runs a 9" auger.
The clay we have here is tough enough, you can't dig it with hand post hole diggers. First cheapy set of those I had, I socked it in the clay, spread the handles, and promptly bent the metal.
My 2200/PHD has never balked at digging in the clay. With a proper cutting edge and adjustment, should work fine.
ron
Tom_H said:
Barryh,
Thanks Tom, I never had any doubts that my 1500 can handle a post hole digger. I just want to make sure I get the one with the best fit. I plan to tool around in the back woods with it and want enough clearance to maneuver around without getting hung up. The 1500 is slightly lower than your BX2200 for sure.
Thanks for the thread link. That doesn't surprise me at all, some great pictures there. I have every confidence in my 1500. If I could justify a woods backhoe I would buy it in a minute. I just don't have enough projects around here to warrant buying one at the moment. Sure looks sweet mounted on his tractor. ;)
/ Post Hole Digger for BX Series #13
Barry,
If you are gonna tool around in the woods, you might want to make sure you have a skid plate under your BX, if you don't already.
There's a lot of fragile stuff under there that tree limbs just love to break.
ron
RonR said:
Barry,
ron
Thanks Ron, that's on my long list of things to do this spring. I really just bought the tractor late fall early winter. I have read about the plastic fan loosing blades etc. Glad to hear you can dig in clay with no problems. I have a lot of fencing and planting I want to do this year. This should make the work much easier. Thanks to everyone for their comments it's been a big help. ;)
/ Post Hole Digger for BX Series #15
I ran a Leinbach L-7200 on my BX1500 with absolutely no trouble at all. The 3PH geometry was fine and it drilled 36" down at just a tick above idle through tough virginia clay. When the bit encounters a rock, it will either pull it up or just sit there and spin.
Ace, thats one of the units I'm interested in. Now that you say it matches up to your 1500. I'll be looking a lot closer. Got any pictures of that little tractor in action? Thanks a mill for the reply. :eek: ;)
/ Post Hole Digger for BX Series #17
I have that exact PHD. It fits just fine on my BX22, and works well depending on the soil. Power is no problem I usually dig at just above idle. In soft soil, not cliche or real hard packed clay it will dig all the way down to the gear box. Soil here is very hard in most places. I put carbide teeth on mine.
Sounds good, appreciate it. :eek:
/ Post Hole Digger for BX Series #19
Actually, I'm the person that Mr. AceDeuce sold his PHD to. I haven't had occasion to use it. I'm going to be digging holes for my Dad's privacy fence in the spring.
When I mounted it on my 2230 immediately after purchasing, I could lift the tip a solid 6 or 8 inches off the deck. I could definitely see dragging the tip if you transport the unit with the auger attached...unless your project is at the end of your driveway, I'd say it is far more likely that you would drive to the project site WITHOUT the auger attached, then slap it on once you get to where you don't care if the tip drags/digs in the ground.
I think the only difference between the BX1500 and my unit is the high of the tires.
/ Post Hole Digger for BX Series #20
When I drive mine around from place to place I take a tie down strap and pull the auger forward and cinch it up. that gives you plenty of cleareance and keeps the auger from swinging back and forth.
