Post Hole Digger and Rocks?
   / Post Hole Digger and Rocks? #21
All this research is because the local fence companys want $9k to install a fence in my back yard.
~Kevin
Tell them if they throw in the shed they got a deal..
   / Post Hole Digger and Rocks? #22
9k, wow. I had a fence company do 2 sides of my property (a bit over 2500ft) for just over 6k. Of course mine was just 5 strand barb wire and entrance gate posts (I did a custom gate). Depending on the type of fence having it done by a company is sometimes cheaper. In my case I just didn't have the time. You also have to consider the cost of the PHD and how often after this project you will be using it.
Good luck.
   / Post Hole Digger and Rocks? #23
Whistle, I went to my local tractor equipmeny store and walked around the lot and I got to see a Land Pride PHD next to a Bush Hog 2102. Though I am not sure of the Land Pride model number I have to agree. The Bush Hog looked, felt and smelled of durablity and strength. The Land Pride model did not.
~Kevin
I priced having the fence done by a contractor also. By doing it myself it paid for my post hole digger, three point fence roller, and some really good fencing tools with money left over. All this stuff is sitting in my barn and is paid for. It was well worth the effort for me to do it myself.
   / Post Hole Digger and Rocks? #24
Wow. I have to put in a fence too & thought that it would be as simple as getting a PHD and letting it do the work. Good thing I read this.
MMH,
It can be just that simple depending on your soil type. I live on the edge of what is called a Boulder Moraine and I have some pretty heafty rocks to deal with (as one can seen in the picture below).
When I was younger I dug 300 holes with an old fashion PHD, in the sandy soil of FL. Up hear in CT though digging is not so easy. A 3 foot hole here might result in a 4x4x3 foot hole.
~Kevin
   / Post Hole Digger and Rocks? #26
~Kevin
I know that you acknowledged that you did not know the size of the Land Pride unit and everyone should take that for just as it is. I
just wanted to emphasize that when comparing any implement, always compare apples to apples. The Bush Hog 2102 would compare to the LP PD25 and the BH 2103 would compare to the LP PD35. Bush Hog has 3 sizes of PHD where as Land Pride has 4 PTO units and 2 hydraulic units.
My guess is that the Land Pride unit was one of smaller size-rating such as either the PD10 or PD15.
MTR,
I agree. I was not comparing peaches to peaches. You are totally right. I will have to take this onboard for future examples. :)
I am not even sure if the small Land Prides can be used with the heavy duty augers. I am thinking the down pressure kit is seriously lacking power.
Thanks,
~Kevin
   / Post Hole Digger and Rocks? #28
Heavy duty will be the way to go on the phd. A friend over in the Mystic area bent one of the phd support arms by trying to force the auger down. Not sure what kind of fence you're planning but for my wood fence I moved the posts to where I could get a post in without obstruction. This created a problem for using 8' premade fence sections. For one side I custom made the fence myself so that the lengths were of flexible length. For the back fence with similar post issues I actually made nailing rails between and flush with the posts which allowed me to use premade 8 ft fencing. I have a larger project where I intend to use a post driver with a rock spike. Again if I run into heavy issues I will move over. Depending on your soil type ( see NRCS web soil app) if you do not have shallow bedrock you should be successful in getting posts in. I know that those folks with bedrock issues anchor a plate into the rock that will hold the post or make a cement post to the surface and then anchor. Good luck.
   / Post Hole Digger and Rocks? #29
Consider renting a "post pounder". Ive put in aprox 400 cedar posts in the past year (8' long and 4 - 8" in diamiter). Rented a pounder for $80 a day and $25 an hour if I want the guy to operate it for me. We pound aprox 90-100 posts a day, 6 minutes per post (average time). Small 3-4 inch rocks are no problem, Big Rocks are a Big problem (fortunatley I have only hit 2 of those).
Very economical way to do it, they are solid as soon as they are done, and its very very quick. If I had to Drill/Auger 400 holes, Id stil be there !
Not sure that works for you or not, but its worth considering
   / Post Hole Digger and Rocks? #30
MTR,
Thanks,
~Kevin
When you say heavy duty auger, do you mean heavy duty or do you mean bigger diameter? I believe that heavy duty works on all the PHD, but 12" is the cut off size of the PD10 & PD15. The other 3pt PHD go up to 24".
How do you mean that the down pressure kit is lacking power? I am fairly sure that everyone's down pressure kit puts out about the same force which is 500lbs. There is a relief valve that is part of the kit that regulates this pressure. I know that before I put my down pressure kit on, I had holes that would take hours to get drilled between drilling and waiting for water to soak in. Now with the down pressure kit, I have not had a hole that has taken me more than a minute or two to drill. That has been with 18" and 24" augers. ;)
Massey Ferguson 8200 Flex Platform (A59814)
Massey Ferguson...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A57453)
2004 Freightliner...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
KBH 25T Tender (A56438)
KBH 25T Tender...
