post hold digger on tc24da ?
   / post hold digger on tc24da ? #1
jeffd
cass city, MI
TC24DA
I woud like to get a post hold digger for my tc24da. I have never used a 3 point auger before, I have always made my holes the hard way. How much travel does the auger have on the tc24 ? I noticed that my 3-point looks like it does not move far, maybe 8 to 10 inches. If I go to the expense of getting a post hole digger, I want to make sure I dig real holes, 36 to 42 inches deep. Any suggestions would be appreciated.
   / post hold digger on tc24da ? #2
I borrowed a post hole digger when I put the poles in for my garage. When it was in the up position I had probably 6 - 8" of clearance and I was able to get 36" holes from a standard PHD. Now I did have to readjust the PHD from the way the guy had it that I borrowed it from. I also dug the holes in 2 stages. Stage 1 was standard way of digging. Stage 2 was lift the auger up, reposition the tractor and lift the front w/ the FEL and redrop the auger in to the hole to get the final few inches. No problems. I don't remember how many holes we actually did, but it was probably around 20.
Hope this helps.
   / post hold digger on tc24da ? #3
I use a PHD from TSC on my TC24D with absolutely no problems. I've got 9" & 12" auger bits and can dig until the gearbox is nearly in the ground. 36" to 42" deep holes are no problem, I've probably dug about 100 last year. I use the PHD for tree & shrub planting, I dig 3 holes close together in a trianglular pattern and scoop out the spoils with a shovel. The PHD has also helped with 2 decks.
You should have no problem using any of the standard PHD's on the market with the TC24DA
   / post hold digger on tc24da ? #4
I have found Greenline Mfg to be a good unit as well the, I have the EM5000. I'm pretty sure I learned about them from this site, and I thank those who mentioned them ( I forgot the names-sorry) The EM5000 fits very well on the smaller cuts as well as sub-cuts. My JD 4100 only has 17 PTO but it handles a 12" auger in idle without a hiccup. Of course if the soil was rocks or clay I guess my song would be different? /forums/images/graemlins/grin.gif
The auger is well made with replacable teeth at the tip
Duc
PHD by Green Mfg
   / post hold digger on tc24da ? #5
I use a TSC PHD with 12'' auger on my TC18. I dug 19 holes for my pole barn with no problems. I went as deep as possible (gearbox almost in hole) and I got down about 46''. You will have no problem with the TC24 until you hit a big rock. If you think the rock is very big, then set your post on it. That's what I had to do with one of them.
Good luck,
Dave
thanks for the info. you really built up my confindence on this little guy. I just cant believe how much I have been using it. I probly should have gotten the 30hp, but other than a serious lack of rear weight, it does ok using the FEL. I threw a blade of my belly mower last week, but all the hdwe was there, I just had to put it back on. Dealer forgot to tighten 1 hyd hose, that was an easy fix. Now its time for my 50 service (more like 60 hrs). Getting ready for winter next. Glad I got a nice shed to park it in.
   / post hold digger on tc24da ? #7
Northern Tool's model 1199 is the Greenline EM5000. I just had one delivered today with a 9 inch auger. Works like a champ with my TC30. Give it a little throttle and it'll even dig through the hard red clay we have here in central VA.
   / post hold digger on tc24da ? #8
i have a worksaver post hole digger that i use on my NH 1520 (23hp) and it has done a tremendous job on the property, it will dig you a 12" hole in no time flat, be carefull if you hit a rock, back of on the pressure and it will pop that rock out of the hole, if you try to drop it down hard on the rock you will break a shear pin.
i have put in 300 trees, not to count how many land scape bushes and rose bushes, and making three holes together and shovelling out the hole you can get a pretty big tree root ball planted easily. i did have to replace the auger points as they wore out in this heavy rocky soil. but work saver sent them right out no problem.
alex
   / post hold digger on tc24da ? #9
jeff,
also be aware that a posthole digger is one of the more dangerous pieces of equipment you can attach to a tractor, you definately dont want anyone near it when it is running, and stay in the tractor seat. there have been amy serious injuries with this piece of equipment.
i have also seen some pretty big rocks thrown quite q distance with a lot of force by my post hole digger, so be carefull.
alex
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
2015 Toro Workman MD Utility Cart (A50322)
2015 Toro Workman...
Vermeer TC4A Hydrostatic Trench Compactor (A50322)
Vermeer TC4A...
Massimo MB100 Mini Bike (A50121)
Massimo MB100 Mini...
2018 Kubota KX033-4 Midi Excavator (RIDE AND DRIVE) (A50774)
2018 Kubota...
Unused 2025 CFG MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
