Post Driver
/ Post Driver #1
blackpowder
I ordered a Shaver pd-8 hydraulic post driver today for my L-39, with the three point hitch brackets. I'm thinking once I have the backhoe off, that the driver will attach to the remote that the hoe uses. What do you think?
Thanks.
/ Post Driver #2
If it doesnt hook up clean & quick I'd bet you could plumb it quite easily.
Good luck and BE CAREFUL with your PHD.
/ Post Driver #3
Thanks.
Yes, you hook up to only one side of the remote for your pressure to raise the PD ram. Return from thr PD goes directly to the reservoir, usually directly to the filler hole via a large lo pressure hose, in order to have least flow resistance and give a fast drop.
Larry
2006 Kubota L5030 (A64126)
2006 Kubota L5030...
Woods Brushbull 60 3Pt Mower (A66285)
Woods Brushbull 60...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
