Post driver - what do you use?
   / Post driver - what do you use? #11
Is that return line an easy add or does it require modification to the reservoir?
Sometimes it easy sometimes it is not. On older tractors I have had this on I was able to take the metal hydraulic fill cap/plug and either thread a 3/4" pipe into it or I have brazed a 3/4" pipe to it and it worked well.
On my current Mahindra 2638 I have come up with a rather janky way to make it work but I don't like it nor will it hold up longterm, but I can get a job done. I am looking to have an adapter made that threads into the tractor that will accept a 3/4" npt pipe.
   / Post driver - what do you use? #12
I've had an HD-8 for probably 10 years. I use it on my B2710, flow doesn't matter it just speeds up raising the ram. The return does matter, has to be directly to someplace with no restriction. I was able to get a fitting with an o-ring that fits the fill opening on my transmission, it's right between the 3pt lift arms so that was easy to plumb. Every tractor is different, my neighbor has a JD which has threads on the fill port so it was easier for him to make something up.
We have a lot of rocks (glacial till) which makes pounding difficult and not very precise. The posts move around as they push the rocks out of the way. I've found putting a dull point on the post helps, even though shaver says not to do that. If you're luck you won't have rocks. If you try to pound posts with slots or holes, like for a split rail fence for example, the pounding will often split the post. I keep the post solid, I also buy oak posts from a local sawmill. When I used treated pine posts, I had some split but not too bad. It helps if the top is square/flat so the ram hits the whole surface and not just the edge.
It also helps if you have a top and tilt, it makes it easy to get the thing plumb. Mine has the manual crank for plumbing the machine, that's a real slow, knuckle busting process. So if you don't have top n tilt, get the hydraulics on the pounder.
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
2012 CATERPILLAR 312EL EXCAVATOR (A52707)
2012 CATERPILLAR...
2013 JLG SkyTrak 6042 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2013 JLG SkyTrak...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
8 Cubic Yard Dumpster (A55851)
8 Cubic Yard...
FORD 8530 TRACTOR (A57192)
FORD 8530 TRACTOR...
