Post Driver...anyone regret it?
/ Post Driver...anyone regret it? #21
<font color="blue"> Do you use the stands like that pic shows? I have never even used mine except to store it. </font>
Yep. I drop the driver down until the outriggers (see attachment) are almost on the ground (in case I have to move the tractor backwards/forwards), then I center the bubble, drop the driver the rest of the way so all the weight is on the outriggers, double check the bubble and begin driving the post.
/ Post Driver...anyone regret it? #22
<font color="blue"> what kind of power does it take to run a post driver? </font>
My TC25D does fine with the HPD-16 even though the Worksaver site indicates the minimum PTO hp is 30. The bigger issue is the gpm of the tractor. The gpm determines how fast the ram goes up.
<font color="blue">Also, even if you have the power does it require a sizable tractor to stabilize a unit doing that kind of work? </font>
All the weight of the driver is on the two outriggers. Set the brake on the tractor and pound the posts in. If you hit a rock, it does shake the 3ph area, but no worse than dragging a rotary cutter around.
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
HD Quick Attach Grapple (A66408)
HD Quick Attach...
Cultivator (A62613)
Cultivator (A62613)
Mini Skid Steer (A60352)
Mini Skid Steer...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
