Post deleted by wrn9510
/ Post deleted by wrn9510 #2
Re: BX2200
Bob D.,
I ordered a BX2200 with a 60" belly mower and the LA211 loader with standard valve last week for $12,149. I'm not getting the grading box, so you'll have to find out about that from someone else. Delivery is tentatively scheduled for this week, so at least the dealer that I bought from had them in stock. (Western PA)
Stush
/ Post deleted by wrn9510 #3
Re: BX2200
Stush's price falls right on target for what people have reported paying since day one for the BX. Occasionally, some one has posted that the dealer is asking full list, but they resolved that one by hitting another dealer. Availability seems to be a dealer/local/regional issue. Some people report finding them on the lot, others an open-ended wait. Visit or call all the Kubota dealers within a reasonable distance. Who knows, someone may have one ready to go. Also, use the Internet (Caver's plus some others will ship). Good luck.
Re: BX2200 (Stush)
Stush,
Thanks for your come back. Would it be possible for the name and address of the dealer you bought from and, do they have a web page or e-mail address??????????
Bob D - Williamsburg, VA e-mail wrn9510@erols.com
/ Post deleted by wrn9510 #5
Re: BX2200 (Stush)
Bob,
Check your email for the dealer info that you asked for. Since I haven't taken delivery of my tractor yet, I opted to hold withhold this info from the forum until the deal is closed.
Stush
/ Post deleted by wrn9510 #6
Re: BX2200
I just purchased a BX2200, 54" deck, LA211 Loader for $12,400. Edwards Equipment Danville, IN. I traded in a Cub Cadet. Dealer had my unit on order for over a month. Dealer had trouble getting units. I saw an 1800 before I bought. The loader did a great job on the 1800 too. I bought a 5' blade at Tractor Supply store $175. They also have box scrapers. I could not justify $400(4' Box) for a landpride or woods. Speaking from my new experiences with the BX, you need somekind of counter weight on the rear! I really am pleased with the quality of the tractor.
/ Post deleted by wrn9510 #8
Re: BX2200
For loader work, a counter weight is necessary. I have used a 5' and a 4' blade, but also have wheel weights. Do you have any tire ballast?
/ Post deleted by wrn9510 #9
Re: BX2200
No, I really don't wan't to head that direction. I know how caustic it can be over time. I don't like the looks of rear wheel weights. I don't use the loader that much(25% of the time). I may mount weights on the back of my blade. I can make some sort of brackets to hold or hang the weights.
/ Post deleted by wrn9510 #11
Re: BX2200
rgb: Did you ever notice the Owner's Manual under the heading Rear Ballast (p.37): …. 'And the ballast should be removed when it is not needed. The weight should be added to the tractor in the form of liquid ballast'. Gee, I guess Kubota would like for us to fill the tires when attaching the loader, and drain when finished /w3tcompact/icons/wink.gif. I agree with you, no thanks Kubota. There are easier ballast to add and remove.
/ Post deleted by wrn9510 #12
Re: BX2200
On the subject of removing ballast....
When you use front ballast weights, it is normally required to be removed when you attach a loader. The same is true that a ballast box on the three point is normally removed when it is not needed (also hard to use the three point for anything elese while mounted) /w3tcompact/icons/smile.gif
Don't believe there is any way to translate from Japanese to mean to remove water ballast in a tire and then put it back in. /w3tcompact/icons/smile.gif
I carry about 1500# in water ballast at all times in the tires. It helps with the loader AND it also helps significantly with stability of the tractor as well as traction when using any ground engaging equipment.
/ Post deleted by wrn9510 #13
Re: BX2200
>I really don't want to head that direction. I know how caustic it can be over time.
Actually a mix of propylene glycol (non toxic)automobile antifreeze (contains rust inhibitors) in the tire is not considered corrosive. Calcium Chloride is sometimes contained in tubes for this reason. I have seen tractors that had CaCl in the tires for over 20 years and still looked pretty good. No one in Texas will put it in tractor tires anymore and prefer the antifreeze mix.
/ Post deleted by wrn9510 #14
Re: BX2200
Wen; Is your fluid in the back only, or front and back?
(Another theory: Kubota would like us to own two sets of rims and tires. One with ballast, and one without! /w3tcompact/icons/smile.gif)
/ Post deleted by wrn9510 #15
Re: BX2200
Front and Rear tires are filled with propylene glycol 40% and water. After that expense, wheel weights don't seem so expensive after all, do they? That is approximately 1000# on the rear and 500# on the front. The weight on the front is only necessary if you are pulling heavy loads or have heavy loads on the three point. Don't load the front tires if you do a lot of highway driving. Always have something on the three point when using the loader. I believe Kubota recommends about 850# in addition to the tire ballast.
If you ever try to handle a 1200# tire, you would not really want to change them very often! However; the improvements in the tractor are so significant, that I doubt that you would ever go back to unfilled. My goal is to simply keep all four tires firmly on the ground under all normal operating conditions.
Another interesting tire book (in additon to Firestone which is scanned) is the Goodyear Farm book which is .pdf format and is excellent. It is just not all there yet. It recommends the proper weight to go along with the rated HP for tractors to get the proper traction from the tires on the tractor. Kubota must have been reading it because it comes out right on the nose. /w3tcompact/icons/smile.gif /w3tcompact/icons/smile.gif
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Tires (A66734)
Set of 4 Unused...
2011 DRAGON  4 AXLE CRUDE TRAILER (A67714)
2011 DRAGON 4...
ELLIOTT MAGNETEK 60KW DIESEL GENERATOR (A67714)
ELLIOTT MAGNETEK...
2012 COMPTANK CORP. 130BBL FIBERGLASS ACID TRAILER (A67714)
2012 COMPTANK...
Kaufman 47ft. Gooseneck Tri Axle Car Hauler Trailer (A66736)
Kaufman 47ft...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
