Possibly buying a Massey Ferguson 203 TLB, anything to look for?
   / Possibly buying a Massey Ferguson 203 TLB, anything to look for? #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
Looking for a tractor to run a round baler with as well as move round bales with and I ran across a Massey Ferguson 203 TLB which we are going to look at it tomorrow.
Looks like PS fluid leaks around the steering column are common in that vintage, need to check for slop around the pins for the loader and backhoe of course, clutch freeplay, gears shifting smoothly.
Anything else to look for?
The seller says that it has a PTO (need to verify that its independent or live for baling) and that the backhoe is removable.
On the todo list if we get it (in order of importance):
1. Add a ROPS and a seatbelt
2. Change all hydraulic fluids, oil/filter, fuel filter, change/clean hydraulic filter
3. Replace shifter boots (most likely will need to be done)
4. If it doesn't have a drawbar, get one (looks like a Tisco SDA75 should fit)
5. Setup rear remotes (have a power beyond capable valve out of a forklift that should work)
6. Build bale spear to replace loader bucket
7. Setup the forklift mast that I have to use the backhoe mounts
Thanks
Aaron Z
   / Possibly buying a Massey Ferguson 203 TLB, anything to look for? #2
Sounds like you've got a good handle on it. My only concern would be the removability of the backhoe/existence of a functional rear end for your purposes. Beyond that they had Perkins diesels so parts should be easy enough to come by for the engine. Good luck, hope it turns out to be worth your time.
   / Possibly buying a Massey Ferguson 203 TLB, anything to look for? #3
If it comes with a backhoe and it has a PTO already there are there three point lift arms attached or included as well?
I don't think so, but we shall see. IIRC, a 3 point could be added by swapping in a different top plate, but I don't think that we will need a three point hitch for what we plan to do with this tractor. It will likely have either the backhoe or the forklift mast on it unless it is being used to make hay.
Aaron Z
From what I have seen, there are two big bolts that you loosen up and then the backhoe can be walked off. I will know better when I see it tomorrow.
From what I can find, this was built off of any of the same parts as the 35 or 135 depending on the build date.
Aaron Z
Bump for the day crowd.
Aaron Z
We didn't end up buying it. Turns out the seller was confused and it did not have a PTO on it. Too bad, it was a nice looking tractor.
Aaron Z
   / Possibly buying a Massey Ferguson 203 TLB, anything to look for? #8
That stinks. The search continues!
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
2020 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A53426)
2020 KENWORTH T680...
2013 New Holland BR7060 (A50123)
2013 New Holland...
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
