possible with hydro?????
   / possible with hydro????? #1
NHeuro
europe
NH tce 50 for the previeus see Bio
I saw this picture in a post, it is a tc with 12*12 but i don't think it will be possible to pull this on high speeds with a hydro
or am i wrong /forums/images/graemlins/laugh.gif
   / possible with hydro????? #2
The type of transmission on the tractor does not matter for this job - it is the combined weight of the towed attachments, trailer and hay that matters.
   / possible with hydro????? #3
</font><font color="blue" class="small">( I saw this picture in a post, it is a tc with 12*12 but i don't think it will be possible to pull this on high speeds with a hydro
or am i wrong /forums/images/graemlins/laugh.gif )</font>
I think your wrong. The transmission has nothing to do with whether a tractor can pull a load at high speeds. If a 12*12 can do it so can a hydro. To me a hydro for baling would be nicer than the standard transmission. You can easily adjust your speed to the load and keep your PTO going strong. The tractor in the picture to me looks like it is too small to pull a fully loaded hay wagon at high speeds down the road. I am sure it can get the speed up there but if you would have to stop fast I just don't think you would. Transmission has nothing to do with that.
murph
   / possible with hydro????? #4
</font><font color="blue" class="small">( I am sure it can get the speed up there but if you would have to stop fast I just don't think you would. Transmission has nothing to do with that.
)</font>
Murph, I disagree with you slightly. I think the hydro is much better for stopping since the hydro adds to braking when you lift the pedal. With a gear tractor, you only have the engine to aid in braking. In my estimation, the only thing a gear tractor does better than a hydro is pull a plow... and maybe build up muscles in your clutch pedal leg. /forums/images/graemlins/smile.gif /forums/images/graemlins/wink.gif
   / possible with hydro????? #5
I agree with jinman's comments.
   / possible with hydro????? #6
Traction is the limiting factor concerning braking in this example. Tire to surface friction will be the limiting factor here, not mechanical braking regardless of transmission type. Conventional wisdom says the typical safe trailering weight is 2X tractor weight without trailer braking.
   / possible with hydro????? #7
Jinman,
I agree with you and maybe I didn't make myself clear. I was more talking about the tractor size itself and stopping with the large load behind it. The tractor in the picture just looked a bit small to be pulling a baler and a full wagon down the road. Yes hydro will stop better than manual. In the case in the picture I just thought either wouldn't stop fast enough or safe situation.
murph
edit: in fact in my case with the hydro you have to be careful not to let off the pedal too fast or I will be wearing the New Holland symbol on my forehead from the steering wheel.
i agree but i will say one thing
I had a tc 45 da and it was impossible to start at the hill with my trailer in II turtle and rabbit, so i need to select the I gear for a time and now i can start in C group (highest) and in 2nd or 3th so a hydro will do the same thing but slower.
But the hydro is better for mowing and FEL work in narrow places.
   / possible with hydro????? #9
Torque is Torque.
Speed is Speed.
The relationship between them really doesn't depend much on the type of transmission, all other things being the same.
I guess you could also start your car in third gear - just up the engine RPMs, feather that clutch, let it slip and burn a while until you get some speed and the torque requirements won't stall the engine.
But then again, why would you want to pull a trailer that is so heavy up a hill at high speed?
I just don't understand the point of your posts.
   / possible with hydro????? #10
</font><font color="blue" class="small">( I had a tc 45 da and it was impossible to start at the hill with my trailer in II turtle and rabbit, so i need to select the I gear for a time and now i can start in C group (highest) and in 2nd or 3th so a hydro will do the same thing but slower.
)</font>
I do agree with that statement. I don't know if I "over challenge" my tractor sometimes, but I have hills (or parts of hills) I can't climb in any gear but low-turtle. I'd never consider pulling a bale wagon up those hills though. /forums/images/graemlins/shocked.gif
The funny thing about the picture you first showed is that I don't even think about how much a load it is on the tractor when I look at it. Every time I see that picture, I get a stabbing pain in my lower back and I have to go take 3 or 4 ibuprophen. /forums/images/graemlins/blush.gif /forums/images/graemlins/laugh.gif
Kubota Salt-Spreader (A52384)
Kubota...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
