possible well pump problems?
   / possible well pump problems?
ya ... basically what they did was raise the off peak rates a little and raised peak rates a lot ... but don't worry you get a 10% discount for the green energy act ... so long as you don't mind a 35% increase in your power rates prior to taking it off
   / possible well pump problems? #63
The small heat pump was probably selected because of the limited available well flow. It wasn't sized according to the home heating load. Heat pumps can be very efficient if they are sized right and provided an adequate supply of water. It sounds like you would need a bigger well supply to even consider adequately sizing a heat pump for your home.
A possible solution to consider is adding a hot water heating coil in the ductwork leaving the heat pump, and a small, high-efficiency direct vent boiler to make hot water for the coil.
You would still use the existing heat pump for air conditioning in summer. In winter, the heat pump would primarily function as just a circulating blower. It would also be a functional back up heat source if there ever was a problem with the boiler during the winter.
Ya it turns out (after talking to the guy who installed it, not the guy who did the work for me), that the previous owner who put this thing in, refused to replace the pump in 2007 when he had it installed, so that's why they went with the lower btu furnace (which btw would cost 12k to upsize to the 30kbtu one)
   / possible well pump problems? #66
Check prices for a small boiler and coil setup. The boiler could also be coupled to an indirect water heater to provide domestic hot water as well as heating for your home.
   / possible well pump problems? #67
I have a boiler set up to a air handler and a hot water heater. No heat pump but pretty much what you would have when the heat pump would switch to auxillery heat while linked to a boiler. It works great for 20 years now. I just invested in a solar system for electric, and a wood burning built in stove thanks to the reinvestment act of 2009 and srecs. When my ac finally goes I am thinking on going with a standard heat pump with a boiler as aux heat. I think a heat pump works more effeciently in ac mode. My electricity is now free from the sun. I live in the woods so my wood is free except for the work. No more electric bill, 70% reduction in my gas bill, no need for a gym membership because of processing wood , my land will start to look cleaned up from processing firewood, and it's nice watching the fire warm my house. Cheap scapes hate paying the man. Tom
Bummer on that off hydro deal.:D
But its green technology! its good! Its so good that they are paying solar producers 80c/kwh. This raises our rates to the point that if I don't run the wood stove all the time my bill would be huge, or I'd be sitting <60 in the house.
And with time of use, the rate on peak times is huge,
my dec bill:
1000kwh 6.4c/kwh + 1030kwh 7.4c/kwh for $140.22, or average 6.9c/kwh. Fees on top of that bring it to $311.64 or 15.4c/kwh
this averaged 70kwh/day 26f avg temp
my jan bill with time of use:
off 5.1c/kwh 2100-0700 1866kwh $95.17
mid 8.1c/kwh 1100-1700 381kwh $30.87
on 9.9c/kwh 0700-1100, 1700-1900 688kwh $68.16
$194.2 usage (average 6.6c/kwh) for 2935kwh cost $425.71 or 14.5c/kwh (note we currently have a 10% rebate on hydro ... so the actual bill is 16c/kwh thanks to time of use)
this averaged 89kwh/day 12f avg temp
and just as historic info: aug-sep last year we averaged 63f and used 56kwh/day
since the wife and kids are here all the time we leave the temp at 20 when its heating and 21 when cooling
   / possible well pump problems? #69
I did not make the laws. I am just taking advantage of the opertunities the man is giving me. I do realise rate payers are the footing the bill. In New Jersey rates cannot be effected by more than 2 %. Around new jersey their is a 20 % cap on green power. The utilities can use 10 % of that. Solar power will eventually cost less than utility power. It will be less expensive to invest in green power with out subsidies, than buying utility power. That day is not very far into the future. The problem is their is a cap of 10 % for grid tie in systems. Once that 10% is reached you have to go off grid to go solar. Again the man has put his thumb on the regular guy. The way I see it it's either pay for someone else to do it or get paid to do it myself.
I mean I'm all for going to safer/cleaner technologies, and I understand they are currently more expensive, so to drive expansion and development of them you need to put incentives out there to get people to buy in ... but their rates are insane.
As an example:
a 10kwh system is about $36000 installed. A 10yr 5% loan on that will cost you $381/mo
Up here, we get an average of 4 1/2hrs a day of sun light. Assuming that's the only time you are generating electricity is when the suns out, you will make around $36 a day, break that over a month and you are talking close to $1100/month.
Even taking into account maintenance costs (most of the cost of this system is in the panels not the inverter/cabling/etc) your total costs per month are about 40% of your income. Pretty quick way to make cash if you can flip the bill to have it installed. At that rate, its about 4 1/2 years to pay back the initial loan.
Pickup Truck (A59230)
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
Killbros 1135 Grain Cart (A59814)
Killbros 1135...
John Deere 4510 (A53317)
John Deere 4510...
