Possible to run hyd. pump off of belt? Engine swap question
   / Possible to run hyd. pump off of belt? Engine swap question #1
scottw99
Ontario, Canada
Yanmar 135
Hi, bought a yanmar 135 2cyl diesel in parts with a replacement motor - another 13hp diesel from a thermoking reefer.
With some brackets, and a bell-housing adapter it will bolt up. However, the original motor has a gear driven hydraulic pump, and of course the reefer motor has no hydraulic pump.
Would it be possible to try to run the hyd. pump off of a belt on the engine going in? Another possible issue is that the replacement motor has a water pump on the accessory pulley where the original did not. Possible?
   / Possible to run hyd. pump off of belt? Engine swap question #2
Depends on the pump. Some models will allow the side loading of the bearings caused by the belt and some will not.
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
7046 (A50322)
7046 (A50322)
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
