Possible to run hyd. pump off of belt? Engine swap question
   / Possible to run hyd. pump off of belt? Engine swap question #1
scottw99
Ontario, Canada
Yanmar 135
Hi, bought a yanmar 135 2cyl diesel in parts with a replacement motor - another 13hp diesel from a thermoking reefer.
With some brackets, and a bell-housing adapter it will bolt up. However, the original motor has a gear driven hydraulic pump, and of course the reefer motor has no hydraulic pump.
Would it be possible to try to run the hyd. pump off of a belt on the engine going in? Another possible issue is that the replacement motor has a water pump on the accessory pulley where the original did not. Possible?
   / Possible to run hyd. pump off of belt? Engine swap question #2
Depends on the pump. Some models will allow the side loading of the bearings caused by the belt and some will not.
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
ASV Posi Tool Backhoe Quick Attach (A51573)
ASV Posi Tool...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
