positive battery broke
   / positive battery broke #1
bo gilmore
cub cadet 50" rzt zero turn
I have a 2010 Cub Cadet 50" zero turn... was cutting yesterday & mower just cut off....found positive battery cable had broke...after putting new end on cable & connecting back to battery, mower would not start...just dead like no connection...what can I check to get mower started...Thanks in advance for your help...
   / positive battery broke #2
I'd put a completely new cable on, and THOUGHLY clean all connections, including the frame ground.
   / positive battery broke #3
Why did the cable break? Did it pull hard enough on the battery post to internally break the battery post?
No it didn't...The battery design is flawed & allows battery to move which bends the cable back & forth...clean break at connector..Thanks
   / positive battery broke #5
Have you tried jumping straight to the starter with jumper cables off a known good battery? If that allows it to start, then you can work backward, testing each cable, solenoid, etc until you come to the dead spot.
Thanks for the advice...Much appreciated..
2021 Ford F-250 Crew Cab Pickup Truck (A55788)
2021 Ford F-250...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Hydraulic Dingo Attachments (A47477)
Hydraulic Dingo...
500 Gal. Fuel Tank (A53316)
500 Gal. Fuel Tank...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2006 TerraGator 8104 (A55302)
2006 TerraGator...
