Mowing Position to Clean Mower - 60" MMM
   / Position to Clean Mower - 60" MMM #11
Re: Position to Clean Mower - 60
<font color=blue>Is it possible that this also prolongs the life of the spring itself?</font color=blue>
Trev,
That spring should last MUCH longer than you do unless it rusts, or you overstretch it while removing it or replacing it./w3tcompact/icons/wink.gif
Mike
   / Position to Clean Mower - 60" MMM #12
Re: Taking tension off mower spring
So, what's the secret of getting that spring off without hurting yourself or scratching up the paint on the deck. It has a whole lot of tension and I am about to winterize the deck, but sure would like some suggestions for an easy and safe way to get that spring off?
nhman
I replied to your other post. Hope that helps.
Re: Position to Clean Mower - 60\" MMM
Got the deck cleaned. I leaned it up against a block wall I have and chocked the center wheels although I don't think I had to because it sat good in the gravel next to the wall. Took awhile but it is now in great shape except for some surface black staining that won't come off. I sprayed it with WD40 and now it is sitting in the garage. Thanks for all our help.
   / Position to Clean Mower - 60" MMM #15
but I've never seen rust form.
Boy, are you lucky! I need some of that vegetable oil grass in my yard.
OkieG
   / Position to Clean Mower - 60" MMM #16
Congratulations on getting your deck cleaned. Mine hasn't been cleaned, yet, as you can see.
For both cleaning under the deck and taking care of blades, I use the front loader, with forks. Forks make the job a breeze. In fact, forks just about double the utility of a front loader, in my opinion. They are probably the lowest cost, high use attachment you can have.
OkieG
   / Position to Clean Mower - 60" MMM #17
Here's another view.
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
FENCE PANELS (A58214)
2022 New Holland C327 Compact Track Loader (A56435)
2022 New Holland...
BOAT, MOTOR & TRAILER (A58374)
BOAT, MOTOR &...
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
