Position Control Lever Stiff
   / Position Control Lever Stiff
<font color="blue"> I actually did my work from the front of the tire. But like I said I did have to use a few four lettered words. Taking the tire off would make a big difference if you have the tools to do it.
</font>
Murph I used that same terminology when I tried for the pin from the back of the tractor. I just could not sneak it out with one hand, so I opted to pull the tire. I'll just bet Kris is using that same language fixing his right now. /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif
   / Position Control Lever Stiff #12
So, after playing in the snow for a while, I decided to try this.. I did end up taking the wheel off, mainly because I didn't feel like getting wet roling around under the tractor... Getting the wheel off is not that hard, but getting a loaded R4 with tire chains back on is a bit of a PITA.
I am not sure how far I backed the nut, I kept backing till it felt 'right'. What a difference this makes. The lever is much smoother. Too bad they dont come like this from the factory.
Thanks again Mike, and all of the others who posted tips, and images. I have a few pics, I'll get them posted up a little later..
Kris glad your problem has now been solved. My information came directly from Murph who also helped me, so now grasshopper it is up to you to carry the torch. /forums/images/graemlins/wink.gif
   / Position Control Lever Stiff #14
Position Control Lever Like Buttah!
Mike, thanks! Murph, thank you too!!!
   / Position Control Lever Stiff #15
Re: Position Control Lever Like Buttah!
Hey guys, you don't need to thank me. I got this information here on TBN. I have been helped by many people and I will continue to help others if I have the answer.
Glad it worked out for all of you.
murph
   / Position Control Lever Stiff #16
I'll thank you anyway. I'd also like to thank the many others who've contributed.
Mine has been stiff since I've had it and I thought that one day I'd get around to it. Today was the day! After reading several questions about how long it took and whether or not to pull the wheel, I decided to give it a go and time myself while doing it.
After looking under it, I quickly decided to pull the wheel.
It took a total of 20 min. Here's the break down.
5 min to jack it up, pull the wheel, roll it out of the way.
6 min to pull the cotter pin, make the adjustment, replace pin.
9 min to replace wheel, install and torque bolts, put away tools.
I probably could have done it quicker but I started the clock when I walked out to the tractor. I didn't bring any tools beforehand so the time includes fetching tools. I also use a 3-increment torque sequence along with a final torque check once the jack was removed.
Here's the list of tools I used.
2 ton floor jack.
22mm 1/2" drive socket (wheel studs)
1/2" drive 10" extension
1/2" drive long handled ratchet
1/2" drive torque wrench
4" needle nosed pliers (straightening cotter)
6" needle nosed Vise Grip pliers (pulling cotter)
10" adjustable wrench (adjust castle nut)
Good luck to all those future adjusters out there. /forums/images/graemlins/smile.gif
   / Position Control Lever Stiff #17
Great timing on this post guys! I just spent 12 hours blowing snow and was thinking how sticky my 3ph lever is. I played with the control knob that governs how fast the hitch drops because mine would go down with a bang or really jerky if you tried to feather it. Adjusting it to turtle mode helped but first thing in the morning I'm going to loosen that castle nut. Thanks for the tips.
Dylan
   / Position Control Lever Stiff #18
Much better. Real easy up and down. No easy job when it is minus 20 outside. Hands freezing to metal. Thanks guys.
ATLAS COPCO XAS 185 AIR COMPRESSOR (A52708)
ATLAS COPCO XAS...
AG-SPRAY 300 GALLON SPRAYER (A52708)
AG-SPRAY 300...
2021 P&J 40' GOOSENECK TRAILER (A52708)
2021 P&J 40'...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
JOHN DEERE 750 (A58216)
JOHN DEERE 750...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
