porwreverser JD 5525 will not move.
   / porwreverser JD 5525 will not move. #1
wjkrostek
palmer ak
ford 3000 JD5310 Ford947 JD5525 Farmall 400
anyone out there had fixed their problem. please share how you did it. my 5525 starts sounds good but will not move.
I should have added this information, no gauges light up, no RPM. when I turn the key on no light show. keep turning key and she starts and sounds good. 4way flasher work but not turn signals. Thanks for looking. Mary Christmas
   / porwreverser JD 5525 will not move. #3
Since you are describing electrical issues as well as not having your power-reverser engage, I would suspect that you are not getting power to the various solenoids on your transmission valve body and the power-reverser feature is staying in neutral:
I would start with checking fuses, then seeing if you are getting power to the reverser switch and go from there:
Power-reverser has it's own separate secondary fuse block as well looks like part 21:
   / porwreverser JD 5525 will not move. #4
That has a TL-200 hydrostatic transmission. Two things come to mind that would make it suddenly not move at all (there are some others as well). Either the freewheel-release lever (typically at the back of the machine; check your manual) is set to freewheel mode. Or the transmission drive belt fell off a pulley.9apps
   / porwreverser JD 5525 will not move. #5
Where did you get that information? I'm relatively certain none of it is correct.
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2018 INTERNATIONAL...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2017 FREIGHTLINER CASCADIA TANDEM SLEEPER (A52576)
2017 FREIGHTLINER...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
New/Unused Quick Attach Rock Breaker (A51573)
New/Unused Quick...
2803 (A50460)
2803 (A50460)
