Portable shelter?
   / Portable shelter? #1
winchman
western, pa
kubota 2410 with loaded R4s
I'm going to buy a portable shelter to keep my tractor out of the weather. I'm considering the 12'+20'+8' heavy duty deluxe model from www.sheltersofamerica.com or one from "cover-it". Does anyone have any experience with one of these shelters or the two manufacturers? Does anyone see the advantages or disadvantages between the house or round style? I think I want to go with the one from Shelters of America. Any info would be appreciated.
Thanks,
winchman
   / Portable shelter? #2
winchman,
Have you thought about a shipping container? A guy at work
just rented a 12x8x20 footer for $50 a month. $75 to drop
it off and $75 to pick it up. $1,700 to purchase. New or
repaired floor, sand blasted and painted. I have seen
contractors using them as offices on worksites. Cut a couple
of holes for windows and doors...
FYI,
Dan McCarty
   / Portable shelter?
Dan,
I have never seen a shipping container in my area, but I guess it would work. I'm looking at a total of $600 with shipping for one of the shelters that I mentioned. Can't decide between the round or, house style?!? Which one would you get?
Thanks,
winchman
   / Portable shelter? #4
If you're in an area with any snow I'd go for the arch. Sheds snow a lot better and is more stable in high winds because there's no flat side to the wind. Downside is you get a little less headroom/volume but if you just want storage for yout tractor that's probably not an issue. BYTW - frined of mine bought a shipping contained as a storage shed. Forgot dimensions/price but it was pretty reasonable and is about as sturdy as you can get. Probably not quite as asthetically pleasing though........
   / Portable shelter? #5
winchman,
I would get a rectangular shelter. Round just would not seem
as efficent usable space wise... And my barn layout is
24'x32'. Course its going to be awhile before it gets built.....
Later,
Dan
   / Portable shelter?
gerard & Dan,
Snow and wind can be factors here in the north, but I also see Dan's point about the useable space. Hmmm...Decisions!
I wish I had the $$$$ right now to build the barn that I want.
Thanks for the replies guys.
winchman
   / Portable shelter? #7
For the money your talking ($600) you could probably build a pavillion like structure and add the walls later. Steel in a pole barn is one of the largest costs.
   / Portable shelter? #8
Buddy of mine bought one of the huge ones that look like a quonset 5 years ago. Last year it ripped to shreds in the wind. Naturally, the manufacturer had an excuse, seems the UV from the sun deteriorates the fabric, and that wasn't covered under warranty.
   / Portable shelter? #9
Coverall is a manufacturer that makes these structures as large as you want. Up to 70 feet wide and as long as you want to go. Used for horse arena's a lot. The fabric is treated with uv inhibitors but they DO have a lifespan, usually 15 years. 5 is too short and may have been inferior/unstabilized material. For a 60 x 120 arena the material itself is only about $4000, so in 15 years you remove the old material and put up the new. NO other maintenance involved so that's not a bad way to go. Also these are not considered "permanent" structures because they can be disassembled and moved so you can't be reassessed on your taxes. A BIG consideration when going large like an arena. Just make sure the material is UV stabilized. (Your normal blue tarps arene't which is why you only get a year or two out of them before they start disintegrating on you. Sun's a nasty enemy to some things...........)
   / Portable shelter? #10
winchman,
I have a Cover-it shed that I put together about 3 weeks ago. So far I am very happy with it. Last winter I had requested a quote from the Cover-it people, and some time around February I received an e-mail "special" on the 12 x 20 peaked top shed - $299.00 plus shipping. This past fall at a local fair Cover-it had a display with a "fair special" $299.00.
It might be worth giving them a call and asking about any promotions going on or comming up. Here are the phone numbers I have: 1-800-524-9970 or 1-203-931-4777.
Good luck!!
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
Bell B30E (A50123)
Bell B30E (A50123)
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A53843)
MCELROY 500 SERIES...
2015 CHEVROLET C3500 SERVICE TRUCK (A51406)
2015 CHEVROLET...
