Portable Generators
   / Portable Generators #71
Even if auto start on a portable generator is not allowed in Canada, electric start, in combination with the remote starter, which can be mounted inside, and the transfer switch, would mean hit the start button, let the generator get up to speed and then flip the transfer switch. Much easier than going outside and using a pull starter.
   / Portable Generators #72
Maybe I missed but but what is the difference between a transfer switch and throwing the main breaker? Is it just that the interlock transfer switch cannot be used until the main is switched off or does it somehow disconnect from grid power?
   / Portable Generators #73
All transfer switches disconnect your breaker panel from the power grid to prevent generator power from going out to the grid. They allow power from the grid or the generator, but not both at the same time. They can be manual or automatic.
Throwing the main breaker accomplishes the same thing, but you have to remember to do this if you decide to use an electrical outlet as an electrical inlet. If you forget, your generator power goes out to the grid and puts lineman at risk as they work to restore your power. It's one thing to put yourself at risk, however I've always believed it was not moral to deliberately put others at risk if I'd forget to switch my main breaker off.
   / Portable Generators #74
Lord grant me patience and give it to me now. How can this be so discussed and so well known and yet people just don't get how essential a positive interlock between the main breaker and generator breaker is. By law, the laws of physics and plain old common sense. The breakers have to be break before make.
   / Portable Generators #75
--Looks like a nice product. $550 - 650. Pricey. Transfer switches at the time were also pricey. If utility companies want them, they should install them. Rate payers already cover all of there money making schemes- they should have to pick this one up if they want it.
Well with this thinking if the government wants you to stop at a stop sign they need to install a remote braking system in your car to make you stop and not hit anybody else.
David Kb7uns
   / Portable Generators #76
David Kb7uns
It's because of fools that don't stop. This will justify some power hungry burocrates into such a scheme.
   / Portable Generators #77
What is this tin foil hat conspiracy scheme about money making utilities ?
   / Portable Generators #78
Manual lock-out switches are not particularly expensive and prevent the chance of backfeeding the grid (and harming a lineman). That's what we use in Boston as it is a manual set up.
   / Portable Generators #79
I never heard tell of an auto start or remote start generator being 100% banned in Canada. There are some circumstances in some applications where auto-start is hazardous and is thus illegal .
   / Portable Generators #80
All transfer switches disconnect your breaker panel from the power grid to prevent generator power from going out to the grid. They allow power from the grid or the generator, but not both at the same time. They can be manual or automatic. Throwing the main breaker accomplishes the same thing, but you have to remember to do this if you decide to use an electrical outlet as an electrical inlet. If you forget, your generator power goes out to the grid and puts lineman at risk as they work to restore your power. It's one thing to put yourself at risk, however I've always believed it was not moral to deliberately put others at risk if I'd forget to switch my main breaker off.
Thanks mike for a useful answer, unlike other on here who like to make a big deal about nothing. I do want to do things right and will most likely end up with a manual transfer switch or I guess I could just pull the meter
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 Audi A4 Sedan (A56859)
2011 Audi A4 Sedan...
Kubota BX25D (A53317)
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
