Portable cement mixer recommendations?
   / Portable cement mixer recommendations? #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
I have a bunch of projects that require setting fence poles, pouring tubes, piers etc. Usually, I rent a cement mixer when I need one and knock out a bunch of stuff over a weekend. My time now is becoming so sporadic that I'm thinking of buying a small portable mixer so I can do things when I unexpectedly find time available. I've always rented this Kushlan and seem to think it meets all my needs, especially when filling post holes. It doesn't have a huge capacity, but for what I do, it's just about perfect. Anyone know of one that might be a better option. I've watched craigslist for used ones, but either real expensive commercial models or the Harbor Freight junk.
I figure when I'm finally done using it, I'll just sell it.
   / Portable cement mixer recommendations? #2
Kobalt 4-cu ft 0.5-HP Cement Mixer...$299 This is what i got at Lowes. Works well. I mixed 2 80 lb bags at a time.
   / Portable cement mixer recommendations? #3
Ditto on the Lowes one. Mine has gone through only a pallet of mix, but it still looks new.
   / Portable cement mixer recommendations? #4
I know this is not a precise response to your question but it may be helpful to some. I have a .5 hp mixer which I have used for years. Takes a couple of bags at a time. A bit awkward to use now that I am older - lifting the bags and moving it around is a PITA and emptying it not so easy at times. So, because of all of that I now frequently use a large bucket and the hand mixer (link below). It is made for mortar but works fine for cement and a lot more portable. Just an idea - it works for me and seems as fast as the large mixer.
Dual Speed Paint and Mortar Mixer
   / Portable cement mixer recommendations? #5
I looked at, at least, three brands of portable electric mixers and contrary to what beowulf says - they are ALL awkward to use - no matter your age. Just try tipping a mixer full of concrete into a wheelbarrow. Without somebody helping by either holding the barrow or tipping the mixer - its almost always a lost cause.
Anyhow - all that BS aside - I have an IMER minuteman mixer that was purchased in 2001 and has worked well. Purchased at Home Depot for $395.
   / Portable cement mixer recommendations? #6
Just get a 3.5 cu. ft. HF mixer for $160 and it will run for many years.
I bought one in 04 and poured maybe 300' of sidewalk, a whole house full basement worth of mortar for blocks, 16x26 garage floor, 8x8 storm shelter with 8" walls all the way around and frost wall and footings for a garage, plus many other small to medium sized projects.
The only thing I had to weld was where the bolts hold the drum on as it started to crack. Still got it with the original motor.
It may be junk but it sure works well.
   / Portable cement mixer recommendations? #7
Mine is a "Wind Mill" brand, it goes on the 3 point of my tractor and runs off the pto. It works REALLY well...
I REALLY like the fact I can fill it "where ever" I want, drive to where I need the cement and dump it right where I need it, using the hydraulics.
I like it much better that the electric model it replaced...
SR
   / Portable cement mixer recommendations? #8
I'm not sure what you mean by portable but I will second the thought that the HF mixer is worth the money. I actually got mine from Ebay a little cheaper than HF but it's the same basic machine. It is cheaply made but I've had mine for years and used it for a number of minor projects with no problems.
   / Portable cement mixer recommendations? #9
The big HF unit needs some reinforcing brackets on the mixer plates and a lot of grease to keep it from wearing out.
Also with a full load it helps to give it a hand to start mixing, but for the money... Mines paid for itself.
   / Portable cement mixer recommendations? #10
I bought the Kobalt years ago. Have only put maybe 20 bags through it but it works and rinses well. When I bought it the HF was a close runner up but after years of scraping mix off metal mixers I was intrigued by the plastic. Which in practice seems to clean easier.
Growing up the family built a duplex and I must have mixed 100 loads of mortar. End of day cleanup was a pain. This isn't.
And remember if you are an honorably discharged military Veteran Lowes has a 10% discount plan.
2021 SANY SY365C9C5K (A58214)
2021 SANY...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2014 Volvo L60G Articulated Wheel Loader (A56857)
2014 Volvo L60G...
LOT: (3) Water Meters, (2) Valves (A59076)
LOT: (3) Water...
2006 Yamaha Grizzly 125 2x4 Utility ATV (A59225)
2006 Yamaha...
2025 CFG H12R Mini Excavator (A56857)
2025 CFG H12R Mini...
