Portable Air Compressor
   / Portable Air Compressor #1
wcampbell47
Platinum Member
Texas Coast
Kubota L3901 ASV Compact Tracked Loader
I hauled a portable gas powered air compressor in the back of my truck for a long time to meet the need of airing up a low trailer tire and/or changing a flat with an air wrench. I replaced the compressor, air wrench and air hose with the following.
VIAIR portable 12 volt air compressor. 4P-Automatic Portable Compressor | VIAIR. So far has served me well and aired up low tires on already loaded trailer. 70 psi no problem. Works on tractor tires as well.
Switched to a battery powered wrench as well.
If you pull trailers often you know you run across under inflated tires frequently. This helps in a pinch.
   / Portable Air Compressor #2
Thanks for sharing. :thumbsup:
   / Portable Air Compressor #3
VIAIR makes great compressors. I've had the 450-RV model for two years now and it does an amazing job. 100% duty cycle and can be run 40 minutes before resting. I bought it because when towing I like to keep tires aired up to spec and that little thing has never let me down. A lot more money than most of the China made compressors available right now, but the way it's made I imagine it'll still be airing up tires long after I'm gone.
   / Portable Air Compressor #4
Interesting. How much does it cost?
   / Portable Air Compressor #5
My wife recently purchased a new car.
No spare but a can of 'fix a flat' and a portable compressor.
Fortunately there was also a card for roadside assistance, (never used to date).
I have her compressor!
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
