lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 8,796
- Tractor
- Bobcat CT 235
96 minus 4.5
If standard framing material is being used...using a double top plate on walls framed with "pre-cut" studs (92 5/8")...Walls will not fit under an 8' ceiling...92 5/8" + 3" for top and bottom plates = 95 5/8"...It is not common to hang ceilings before interior partitions are framed/stood...
If double top plates are required typical pre-cut studs will require further cutting...Also...unless it is a designed bearing wall...any other interior walls are not supposed to be framed up tight under trusses etc...they should be about 1/2"- 3/4" below but close enough to so top plates can be fixed with a framing nail etc. to plumb them...
This guy sort of explains it:
Theres 2 sizes of precuts.If you really want to twist somebody around, ask them the length of a pre-cut stud.
Hint, 96" it ain't.
Anything that is labeled a "stud" is "pre-cut" regardless...
Now I know, but I cheated.![]()
Yeah, in the olden days, the rumor was you could do it, but you had to get it up to about 50 mph. Never tried it, never saw it done.
starting - Push start a car with automatic transmission - Motor Vehicle Maintenance & Repair Stack Exchange
