Popular mythconceptions
   / Popular mythconceptions #371
You should have had Cagney and Lacy on speed dial!
Funniest thing on COPS. They rigged a car to be stolen and had a camera and radio controlled ignition kill and door locks. Before the cops even got to the car, the perp was repeating (practicing) I didn't do it, I didn't do it! As he sat at the wheel of a car he just stole!
   / Popular mythconceptions #372
   / Popular mythconceptions #373
None of You Men here on TBN are "Hen Pecked" !!! ..............................
   / Popular mythconceptions #374
I do not remember being "taught" that but it was commonly known back then (30s-40s)
   / Popular mythconceptions #377
Wires always spark when hot wiring a car and must be drawing huge amounts of current.
Is it even possible to hotwire a modern car?
Bomb makers go by a strict color code, and the blue wire is always the one you cut to disarm it.
All bombs have a digital countdown timer.
   / Popular mythconceptions #378
The most powerful explosives are brightly colored liquids and are kept in see-through containers, often bearing sets of shiny appendages.
People exchanging gunfire indoors can hear each other quite clearly as soon as the shooting stops.
Bad guy boss can absorb magazines-full of ammo and have enough breath to give a two minute speech.
His thug is instantly and permanently disabled after receiving one bullet or a throat punch.
John Wayne.
   / Popular mythconceptions #379
A little cross-over here.
Put your nuts out on the driveway - drive on them - it will remove the husks
To crack your nuts - lay them on a wooden block - ask your wife to whack them with a meat tenderizer
If you wash your nuts to remove the goo - be sure to lay them out to dry or they may rot
   / Popular mythconceptions #380
TBN P!ssing matches are always entertaining and reasonable
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
10' CONTAINER (A52706)
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55314)
2017 Rogator...
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
UNUSED FUTURE FT-XHC MINI PALLET FORKS (A52706)
UNUSED FUTURE...
