Poor Quality Control IMO
/ Poor Quality Control IMO #1
Tractor Dr.
I just purchased a brand new L3130 and after a few hours of operation I found that my bucket level indicator had been rubbing against a hydraulic hose. I loosened the connection and turned the hose away and it seems ok now but the rod wore through to the metal braid on the hose. Another observation is that when I get under load I hear a sharp "Snap" noise right under the fenders. When I get under load in reverse I hear the same noise. I believe this is either wheel to axle loose and/or wheel to rim loose. I'm going to tighten both areas today to see if it goes away. If not, the dealer will be making a trip out to get the machine. While these aren't huge issues, these little problems leaves me disappointed in my dealer. I have a hunch the mechanics who assemble the machines are flat rate vs hourly so they rush through the process and try to get it done as quick as possible to "beat the clock". The wheel tightness wouldn't be as obvious to the assembler's manager but the bucket level indicator was and I can't believe they let the tractor out like that.
/ Poor Quality Control IMO #2
That's a drag! I put some of the responsibility on the dealer as those tractors are shipped in crates and "Some assembly required". After the final assembly, you would think that the assembler/mechanic would take the tractor for a spin and do a general operational check.
That's a lot of doe to spend to find out little things like you described have been obviously overlooked.
They're still a pretty cool machine. Right?
/ Poor Quality Control IMO #3
I agree with you completely! Hoses shouldn't be assembled to rub.
Also, the diagnosis on the wheel bolts is probably dead on. That's a tough one to figure out usually.
The dealer is responsible for this as they do final assembly and prep. Talk to the owner and express your calm, factual but honest opinion. They can't fix it if they don't know about it. The service manager may sweep it under the rug as it makes him look bad, but the owner can't.
jb
UPDATE: Found the problem to be at the hub to wheel. Found bolts and nuts to be only "snug" on both sides. Not "Tight" by any stretch of the imagination. I haven't driven the tractor yet to see if it fixed the problem but I'm 99.9% sure that is what it was. Thinking about taking your advice and calling the dealer. I don't want to raise a huge stink but I just want to vent my frustration out a little bit. Who knows it might be worth some free tranny fluid for my first service (I'm not gonna let them do it).
Bigdad: Forgot to add...Yes, very cool machine!
/ Poor Quality Control IMO #6
Sounds like you've found the problem. GTG!
If it's any consolation, theres been more reports than I care to count on poor dealer prep on all models and brands here.
It's not isolated to just your dealer.
On the BX's the common problems reported were no grease in the MMM's spindles and very low oil in the front axles.
On the B's the common report was the hub's being loose on the axles causing a knocking sound such as you just experienced.
Incorrectly positioned hydraulic hoses seem to be the latest problems cropping up in all models.
I don't want to minimize the lack of a dealers responsibility to ensure the machine he sells us are properly setup and ready to operate without these kinds of issues, but it is common, even among dealers w/good rep's.
If the dealer makes it good and is genuinely concerned that his shop fialed then I wouldn't sweat teh tractor nor the dealer in future dealings.
Congrats on your machine.
/ Poor Quality Control IMO #7
It very clearly says in the owners manual that you should be checking your wheel bolt torque after an hour or two of use. Its just like having the tires changed on your car, once they are worked around a bit the lugs can loosen very quickly. It does not sound like a dealer prep problem.
/ Poor Quality Control IMO #8
I just had a hose blow, my left loader arm cylinder hose was rubbing on the bottom of the loader arm. It started to drip and when I investigated she blew up, almost nailing me in the face. The other side has that same hose out at about 30 degrees so it don't happen, this one was perpendicular with the arm. I got a new hose on waranty, no questions asked (but the dealer wanted the old hose back, Kubota apparently investigates all premature wear items), so I wonder what he's going to say happened? It's pretty obvious how it wore out. It was obviously a mistake in assembly at the dealer but no big deal, they can't be perfect and he made it right. Now if my wheel fell off.......
Messicks Farm Equipment. I respect the fact that the customer should periodically perform checks on a new piece of equipment to find nuts/bolts that may have worked loose. However, they have to be tight first before they can work loose. In other words these were never tight. This symptom was noticed in the first hour of operation. You can imagine my surprise when I heard this sharp snapping noise on my new tractor that had .4 Hours on the hour meter. When I tightened them I got 3/4 turn from each bolt and 1/2 turn from each nut. Maybe my expectations are too high but I think that is something that should not be overlooked on a predelivery inspection.
TD
Lancaster, PA
/ Poor Quality Control IMO #10
TD
Lancaster, PA
I agree.
/ Poor Quality Control IMO #11
After having had over 15 years of experience doing tire relacement-repair work for a major tire dealer. I was taught to make sure that when the unit left our place of business that the lug nuts had better been torqued to the correct specs. There were no exceptions to this and we sure didn't expect our customers to have to do this after we had done the work. If you just had your tires changed and the rims came loose it was because they were not torqued to the correct specs by the one who did the job and these guys didn't have a job there very long that let this happen.
/ Poor Quality Control IMO #12
Seems like an easy oversight if they were rushing to get it done. The other basic mechanic rule is never leave a job like that until it's done. ie: Loosely fit the wheels on, go for lunch, come back to a job that "looks" finished and start on something else.
You have every reason to complain (especially if it did some damage to the rims) and you should get something for that.
Just my 2 cents....
dano
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
4 Bottom Plow (A65640)
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
