Poor man's side by side
/ Poor man's side by side #142
:thumbsup: :applause:
Took today off to get a big chunk done. Here's four hours worth of work.
Passenger's side done
Started tracing fancy curved brackets for body mounts... then just did this
They actually had to be hammered in (pass side needed an 1/8" shim), so we'll see if they stay in place once the body starts moving on the trail
Metal work on the back is done! Turned around to get to the front
I HATE RUST!!!
Hit it with the flapper wheel to see what I was dealing with then cut out the worst spots
Then probably an hour later I had them all filled
/ Poor man's side by side #145
Lotta work if your gonna get rid of it :)
/ Poor man's side by side #146
Looking good! That's going to be a nice side-by-side! :)
Thanks guys.
Meh, it's good practice for me, and a nice rig for whoever buys it... and with any luck I'll play with it a little to make sure it's all good before spring. The bridge is going in on the trail as soon as the frost is out of the ground... the goal will be to see if the Tracker can make it around by itself. Should be fun! :)
/ Poor man's side by side #148
Nice work!
/ Poor man's side by side #150
I venture to guess that 2x2 will last longer then the rest of the vehicle but I get where you're coming from.
2020 BOBCAT E55 EXCAVATOR (A59823)
2020 BOBCAT E55...
2019 FREIGHTLINER M2 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2019 FREIGHTLINER...
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
iDrive TDS-2010H...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
