Poor man's gin pole and limb rake.
/ Poor man's gin pole and limb rake. #1
krue
South Mississippi
MF 135 Perkins Gas
First is my adapted engine hoist. Have used it a few times and it works pretty good.
Next up is my limb rake, built it to drag and pile up the tree tops from my neverending Katrina cleanup project. Works pretty good so far.
/ Poor man's gin pole and limb rake. #2
A cylinder that runs off the tractor's hydraulics would make your gin pole easier to run from the tractor seat. Being poor also, I understand why you are using what you are using...
David from jax
I don't have external hydraulics on the tractor (yet), it's an old MF-135 gas burner, I will put the kit on it sooner or later.
/ Poor man's gin pole and limb rake. #6
I like that limb rake. I see that you made the shanks straight down. If you were doing it again, would you do them that way again or angle them forward?
/ Poor man's gin pole and limb rake. #7
I put a tooth bar on my FEL for just the same purpose - makes a great woods rake for removing dead stuff.
I thought about putting some "rake" on the tines, but since I use it as much to push piles while I burn them I decided to leave them straight.
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2012 Freightliner FLD120 Ambulance (A61573)
2012 Freightliner...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2008 TUSK FG25T-16 WAREHOUSE FORKLIFT (A64276)
2008 TUSK FG25T-16...
TORCH & GAUGES (A64276)
TORCH & GAUGES...
