pool cover removal
/ pool cover removal #1
deereman64
The sun had his hat on so it was time remove the pool cover. I suspect that this chore is made difficult so you end up calling the pool company, but with my trusty tractor its removal was a breeze. You need 2 lengths of 100 ft floating rope. One you thread through the spring clips for one half of the pool.Bring the tractor up to pool fence at the opposite end. Tie the other rope to the clip next to the last threaded one and then thread it through the other clips until you reach the point where the tractor is.Take the rope under the fence thread it through the back hitch and then back under the fence. From there you thread the rope through the remaining clips and tie off at the last one before the threaded clip from the first rope. Hop on to the tractor and take up the slack from second rope. In fact just give a little tension to the rope. Now you can go and pull, with an aide, on the two free ropes and the cover pulls back very easily, as the other end cant slip forward.
/ pool cover removal #2
Mornin Deereman,
Sounds like a good idea ! Got any actual pics ? Thanks ! :)
I was going to but it worked so well i didnt get round to it. By the way, I used the tractor to put the cover on last winter. Hooked one end up of the cover and then pulled the cover over with the tractor making sure that no clips fell in to the water( fear of tearing the vinyl) I then pulled the cover tight with the tractor. You have to be careful at this point as you can put too much tension on and rip the cover, but it made it easy to hook the other clips on.
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
JOHN DEERE 4730 SPRAYER (A64278)
JOHN DEERE 4730...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
3Pt Poly Red Ball Tank (A66408)
3Pt Poly Red Ball...
