Pondering new trimmer/brushcutter
   / Pondering new trimmer/brushcutter #1
HuskerInVA
Loudoun County VA
JD 3520, '71 Case 580CK TLB
I'm looking for a new trimmer. I'm looking at the Stihl and John Deere commercial grade trimmers. Go Stihl and I can't go wrong of course. But how do the Deere products compare. Thinking about the FS90 Stihl or XT140LE Deere. Thanks in advance.
   / Pondering new trimmer/brushcutter #2
I have the Stihl FS130 and absolutely love it. The full harness makes weedeating or brushcutting very easy. Also, my dealer sold me a Shindaiwa cutting blade with chainsaw teeth and that combination will obliterate sapplings up to 3" in diameter and I've actually cut a hardwood around 4" in diameter.
When you are finished cutting all the saplings/trees down, you can switch to the trimmer head in a few minutes and do your weedeating.
   / Pondering new trimmer/brushcutter #3
I've got the husqy like the stihl, and that same blade though I haven't put it on yet.
I'd get husqy or stihl. I seem to recall that people have said bad things about the JD trimmers here - not real JD but rebadged.
I don't think I've ever seen a commercial guy with a JD trimmer. Says it right there.
   / Pondering new trimmer/brushcutter #4
I just bought the Stihl Kombi unit with a few attachments and love it. It makes 1.97 hp and does not blink at anything. I have the commercial 130 model.
Brad
I went Stihl on the chainsaw and was heading for Stihl on the trimmer too. Saw coupon on Deere site for $25 off trimmer and was curious. Any idea who's rebadged trimmer the Deere is?
   / Pondering new trimmer/brushcutter #6
Local dealer says " If you want a chainsaw buy stihl, if you want a trimmer buy echo." He also sales John Deere.
   / Pondering new trimmer/brushcutter #7
I just bought a new Stihl FS90 with the 4-Mix engine and the "bicycle" handlebars this last Tuesday. I also got one of the chisel tooth saw blades for it as well ;)
I was really skeptical about the 4 stroke engine, but my dealer said everyone that has bought one from him really likes them, and so far he's had no returns of any with problems. So, I plunked down my $$$'s. Got home and put my polycut head on it, and went to work. All I can say is "Wow!" I absolutely love it. Much quieter/more pleasant to listen to than a 2 stroke, and it has PLENTY of RPM and power... I rarely, if ever had to use over 1/2 throttle, even cutting the heavy fescue ditch banks along my road. I ran 2 tanks of fuel through it the day I got it, and then ran another tank through it Wednesday.
I've had Stihl's ever since I was a kid (dad bought an FS80 back in the late '70's) and I've got an FS44 and an FS80 myself, and now the FS90. I don't think there's any better than Stihl as far as trimmers. So, you ask, why did I get the FS90 with those other Stihl's? The old ones just have the loop handles, and I really wanted a bike handle unit like Dad's old FS80... much less fatiguing...
I've only got 3 tanks of fuel through my FS90, but so far it's an enthusiastic two thumbs up.
   / Pondering new trimmer/brushcutter #8
I use and XT140LE to clear my woods. No problem on small trees and saplings, grass, vines, briars, ect. I used both the "saw" blade and the quad blade. The quad blade is the best for what I been doing. The saw blade I think would work better for thick groves of sapplings or like conditions. We have stihl and JD on our farm and both perform well.
   / Pondering new trimmer/brushcutter #9
I have a FS130 and really like it, the 4-mix engines are very powerful, quiet, super easy to start and do not smoke. The low end torque and power are very impressive. They are very different from the older 2 stroke versions. Check them out I am sure you will like them.
   / Pondering new trimmer/brushcutter #10
I have a older Stihl 106 its a heavy brushcutter I use with the polycut with . Its a heavy cutter though balances not bad with the loop handle I put on . For my trimming I use a remax bc 3000c I think its lighter and just as powerful . My remax dealer just pulled up stakes and was wondering to about a stihl trimmer . I looked at them and they seem balanced ok . From my research it seems the valves need adjusting every couple of hundred hours not a big deal really . Just my 2 cents hoddykubody
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55218)
NEW 2025 Load...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
TEREX RT665 MOBILE CABLE CRANE (A51406)
TEREX RT665 MOBILE...
377811 (A48836)
377811 (A48836)
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
