Pond Scum
/ Pond Scum #11
Ed--
Ridding a pond of algal bloom is a complex process. If the pond is old enough to have a serious layer of muck resulting from leaves, sticks, dead fish/turtles, etc., then the problem is exacerbated substantially because of the hyperoxygenation resulting from decay. A true solution in such a case might involve actually dredging the bottom, and aeration, etc. probably won't turn the corner. Even with a pond that does not have a lot of muck, I think that unless your son gets both aggressive and lucky, he won't get rid of the current large bloom, which sounds like it probably covers about 1/4-1/2 of an acre, without using Cutrine or another copper product (Tractor Supply sells a different brand, which I believe is cheaper) to kill it off. The good news about these products is that they work almost immediately and used right are not harmful to either flora other than algae or any fauna. When we had algae problems and used copper, we'd kayak around the perimeter just to watch the stuff break up and disappear.
Getting rid of a bloom is, of course, the tip of the scum-berg; the trick is keeping it away. I think that there is essentially universal agreement that managing a small lake to avoid algae depends on aeration and nutrient balance, and there is then some divergence of opinion. Many people add blue vegetable dye to ponds; the effect on the sunlight is supposed to be counter-productive for algae. IMHO, DO NOT use grass carp (white Amur) for algae control; there is a fish called Israeli carp which are supposed to do fairly well, but I don't know from first-hand experience. Marginal plants, water lilies, etc. can help but have to be picked carefully because they can just take over (although most can be controlled with another aquatic herbicide, Rodeo). One resource I found helpful is the website for Inspired by Nature, www.ibnature.com, which is an Ohio company specializing in "holistic" pond maintenance. I was very interested in windmill aeration this spring, but after talking to IBN ended up with a compressor-driven bottom aeration system, which I assume is what you mean by "pump driven." I decided against a windmill-based system because we tend to have long spells of little or no wind when aeration is most important, e.g. in the hottest days of summer, early in the morning. A fountain will aerate only the top foot or so of the water, and so should be thought of as primarily ornamental (but don't discount the therapeutic benefits of moving water; we just finished a waterfall which is a wonderful addition). IBN and others also sell mixes of microbes which feed on algae and really do help but have to be regularly added, and a product called "Aquamats" (www.aquamats.com) which is a fairly-costly (about $100 per each, with 24 recommended for our 3/4 acre pond) system of artificial reefs for ponds. Although skeptical, I bit the bullet on about half the number of aquamats recommended for our size pond, and can report that since about a month after they went in, together with aeration since about May 1 and occasional infusions of microbes, we have been algae-free. They do have a full, money-back one-year warranty.
I do know that you're right about one thing--getting rid of the filamentous algae makes a pond much more pleasant to be around. Good luck!
Rick
/ Pond Scum
Thanks, gentlemen.
Ed
/ Pond Scum #13
Thanks Fishman! Our place is a long-time dream come true.
Here's another photo looking south from our deck. I had hoped to get a nice shot of the valley and the fall colors but by the time I got home the sun was already pretty low (producing long shadows) and it was hazier than hoped for.
Dave
/ Pond Scum #14
Dave,
That sure is pretty! Must be hard to leave and go to work. Heck, my place in the city isn't near as pretty and it is still hard to leave and go to work./w3tcompact/icons/smile.gif
Markv
/ Pond Scum #15
Thanks Mark! Actually, I've found that knowing I'm coming back each night makes going to work a lot nicer./w3tcompact/icons/smile.gif This is the first place I've ever lived where I might just take a vacation and stay home! Plus, this part of the country is really beautiful and my ride in is usually great.
Good luck on your mountain paradise! I spent a little time in Dahlonaga, GA (sp?) when my brother-in-law was an Army Ranger trainer there. Real nice area.
Dave
/ Pond Scum #16
Dave,
You were right close on how to spell Dahlonega, most people miss. Our weekend place (='s favorite place) is about 15 miles east of there, so we know it well. Don't want to give away any secrets about age, but I remember the ranger camp there also./w3tcompact/icons/smile.gif Been a while. They use to train on the area we bought. Given the slopes we have, I do not envy our brother-in-law. Ask him if he remembers the name "Wauka Mountain".
MarkV
/ Pond Scum #17
>>Do any of you all have direct experience with successful control of pond algal scum by methods that are both affordable and practical?<<
Cutrine-Plus liquid applied with a sprayer works for me. There are several internet sites from which it can be ordered.
Chuck in IN
/ Pond Scum #18
The Pond:
Have you tried adding some lime? Raises the PH and just may control the scum.
Egon
/ Pond Scum #20
Egon,
I will add these words of caution. Make sure it's agricultural lime and not quick lime or slaked lime. They may change the pH too quickly and cause a fish kill.
Adding lime is generally considered unnecessary if total alkalinity in your pond exceeds 20 ppm. There are test kits out there for less than $40 which will measure alkalinity.
If your pond has low alkalinity, a <font color=blue>general</font color=blue> application rate is 2 tons (U.S.) per acre. A lot of work if your pond really doesn't need it. If your state fisheries office doesn't assist with these sorts of things (and most don't), you might try hiring a private lake manager <font color=blue>with good credentials</font color=blue>.
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
