blackie65
Just wanted to get some thoughts on the best way to check ice thickness and when you all think it is safe to get on ice. Not with tractor but people and maybe an ATV. Is it best to try and keep snow off of ice?
If you want to skate, snow ruins the surface. We always shoveled then cut a hole and flooded the surface with water that would freeze and make very nice surface.
Mike
Everyone here pretty uch hammered down how thick the Ice needs to be, but my personal preference is to see at least 8". At 10" we take the 4-wheelers out on the Ice and have fun.
But what I use to check depth is a lot cheaper than an auger.
I got a 1-1/2" wood spade bit for a coordless drill. On the backside where it tapers back down to the shank, I grind it flat, so when I punch through I can "hook" it on the underside of the Ice fo get a measurment. But you either need a long bit, or an extension.
THat's a great idea :thumbsup:
Do you use a hose to flood the surface?
I always kept an extension ladder around when we would go on my pond. It is very difficult to pull someone out of frigid water with a rope. An extension ladder gets laid out and distributes the weight. It is also infinitely easier for someone in the water to grab a ladder rung and pull themselves out as opposed to them pulling on a rope.
the safest and best way is to not find out...why take the risk?
Great information so far.
I was in the USCG for many years and spent 8 years flying in the great lakes. Picked up way too many ice fisherman that got into trouble. Saw several that weren't so lucky.
Our motto to the public was "no ice is safe ice"....
Having said that, we would land our 9000 lb helicopter on the ice.....we required 12" minimum. Our rescue swimmers would pre-drill holes to check thickness. Always interesting seeing the ice cracking underneath you....!
The best advice I can give is plan for the worst possible scenario. Strength in numbers. Stay as close to the shore as possible. Ladders - good...Rope is good, or a safety ladder (for egressing a second story house) would be easier for someone to grab onto. Our rescue swimmers would carry "ice awls" in their pockets, to get back on the ice, after they intentionally broke thru. (training)
Always keep in mind it only takes a few minutes in the water to start losing motor skills....and the more clothes on the body, the heavier you are when you're wet...
I've always had a plan in my head to someday dig a "skating pond" on the property.....just a rectangular hole no more than 2' deep, hopefully it would hold water or have a way to fill it when freezing temps are present....that takes away a lot of worries!
Best of luck, have fun, and be safe!!
