Pond Dam Leaking.....NOW WHAT?
   / Pond Dam Leaking.....NOW WHAT? #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
What is the best method to locate where the dam may be leaking? Then, what is the best way to repair? The pond has been around for several years, but just recently started leaking. What should we do?
   / Pond Dam Leaking.....NOW WHAT? #2
Are there any trees on the dam? Brush? What about animal holes?
Odds are that if it just started leaking, than something dug or grew through it.
Wait until it stops leaking. The water will lower to the point of the leak. Then you'll have to do a very careful search to see if you can find where the water is passing through. Odds are that you wont see anything, but you never know.
If you don't find a root or something obvious, than your'll have to seal the whole dam at that level, just above it and just below it. From what I've read, Bentonite is the best thing for this. It expands when it's wet and is the prefered material for sealing leaks.
You spread it over the area and mix it in. Use a roter tiller or a shovel and mix it in real good. Compact and hope you put enough Bentonite into the soile.
That's what I understand, but I've never done it, so I'd suggest you go to Pond Boss Magazine Home Page! and search through there forums. They are the experts on ponds like this site is on tractors.
Good luck,
Eddie
   / Pond Dam Leaking.....NOW WHAT? #3
Search the net for leaking ponds and there is a ton of info.
do you know if that pond has bentonite as a liner?
   / Pond Dam Leaking.....NOW WHAT? #4
try and watch and see if you have muskrats in the pond they are great for diging holes in ponds
   / Pond Dam Leaking.....NOW WHAT? #5
or import a few beavers... they hate leaking water :D
   / Pond Dam Leaking.....NOW WHAT? #6
Chemical dye to locate leak, Sodium Bentonite to repair. Look under oil field supply for Sodium Bentonite.
   / Pond Dam Leaking.....NOW WHAT? #7
Benseal is another trade name for it.
My local Farm/Family Center even sells it under a name like Pond Seal I think.
Just do some calling around. It is often used for lining the outside casing of wells.
I have 6 bags in the garage now waiting for the right time to apply and mix it in.
Best Regards,
James
   / Pond Dam Leaking.....NOW WHAT? #8
My neighbor has a pond. It was leaking. He found the leaks. He simply took a 50 (or 35??) gallon black plastic trash bag and covered the leak. Problem solved. No matter how much stuff he jammed into that hole, it always leaked. The black plastic bag "cap" worked like a charm.
Bob
   / Pond Dam Leaking.....NOW WHAT? #9
Evening Doc Bob
Sodium Bentonite swells when it gets wet. If he had used that and in sufficient quantity, it would have sealed the leak.
   / Pond Dam Leaking.....NOW WHAT? #10
Dozernut said:
Evening Doc Bob
I agree, but this old guy had one thing, no tools and just some plastic bags.
Bob
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
2015 Ford F750 Reel Loader Truck (A52377)
2015 Ford F750...
2024 CATERPILLAR 289D3 SKID STEER (A52705)
2024 CATERPILLAR...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
