Poly blade
   / Poly blade #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
Trying find if woods makes a polymer cutting edge to go on there blades for snow? Or some kind of good alternative?
   / Poly blade #2
Good alternative: lots of people report good luck with a cheap peice of PVC pipe, slit lengthwise, and put on the blade. Works good for gravel drives.
Do you have a gravel drive and want to save the stone?? Or paved/concrete and dont want to scratch it up?
   / Poly blade
I've got lots on concrete
   / Poly blade #4
I had a poly cutting edge and it wore out in 1 season. I think it was ~$100. It definately does not scrape as well. I, too had sensitive surfaces to clean off, but after a season of use, went back to steel.
Have you tried setting up your shoes to help prevent gouging?
   / Poly blade #5
You can find the thick poly cutting edges with a search online. If you want to, buy a horse stall mat from Tractor supply and cut your own rubber cutting edge. They are 40 dollars for a 4x6 sheet. Cut with a jigsaw and drill for mounting bolts.
   / Poly blade #6
a polyurethane cutting edge will be a few hundred bucks depending on your size. If your serious about spending that kind of money i will put you in touch with a guy who will sell and ship them . IMO i would run steel on the blacktop to get the best scraping .. poly is good for gravel and if you run off the drive. the turf damage is less.....
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2006 KOMATSU  D41P-6  CRAWLER TRACTOR (A52576)
2006 KOMATSU...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
FRONTIER CA2072 LOT NUMBER 41 (A53084)
FRONTIER CA2072...
2023 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2023 SMITH...
